  • Guests: 28
Will (38)
Arlecchino (41)
07/24 Jim_VE7UV (65)
07/26 Jorrit (39)
07/26 e.m.c.2 (45)
can a Xenon flash lamp explode?
haxor5354
Wed Feb 23 2011, 12:15AM Print
I just upgraded my HID spotlight by jamming in a xenon flash tube beside the HID bulb. I used a ZVS flyback driver and a homemade flyback transformer to give me about 200V to charge the capacitors. Is it possible if I connect lots of high capacity caps in parallel and make the flash lamp explode?
also can regular HID bulbs be used as a flah lamp since its filled with xenon gas anyways?
1298420152 2063 FT0 180025 10150149717891223 638811222 8549107 6799894 N
1298420152 2063 FT0 180025 10150149717896223 638811222 8549108 2913703 N
Adam Munich
Wed Feb 23 2011, 12:58AM
Yes, they'll go bang if overloaded. It's quite loud too!
As for the regular HID bulb thing, I'm not too sure about that. It might be possible, but it might not be the best option for a flash.
ConKbot of Doom
Wed Feb 23 2011, 12:17PM
+1 on the loud bit. 25+ photoflash caps in parallel into one of said disposible camera flash tubes = prretty loud. So somewhere between 1x and 25x 'nominal' there was a failure. tongue
3l3ctrici7y
Mon Feb 28 2011, 11:36AM
3l3ctrici7y Registered Member #1806 Joined: Sun Nov 09 2008, 04:58AM
However you might try to drive the HID, I would strongly advise against doing anything that would make the HID go boom. It contains mercury along with who knows what other stuff that you should not expose yourself to.
Don Klipstein has a site about xenon strobes.
James
Wed Mar 02 2011, 10:27PM
The HID bulbs are very different than Xenon flash bulbs. Much higher gas pressure, much smaller electrodes. They are likely to fail much more violently if you don't vaporize the electrodes on the first shot. Do not experiment with HID lamps unless you know what you're doing.
Thu Mar 03 2011, 09:30AM
+1 on boom
one time i got bored and hooked it up directly to mains
when i triggered it, it gblinded me nearly with the brightness then later i got bored and did it again and it blew up :3
