  • Guests: 93
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
ATX PSU weirdness
Inducktion
Wed Feb 16 2011, 11:05PM Print
Okay, so I recently acquired an ATX PSU and was using it to supply power to my ZVS driver and other things. It works fine, but when I try to scope something on my circuit, the scope seems to be acting as a ground for the current, and the oscillations stop working, and the ATX psu seems to "short" out. Without the atx psu plugged into any aspect of the circuit it works fine, and I can measure anything on the circuit with no problems.
What's going on here?
TheMerovingian
Wed Feb 16 2011, 11:31PM
It seems to be due to ground issues. This happens when you plug the ground of the scope on the circuit or when you measure?
Wolfram
Wed Feb 16 2011, 11:32PM
The ground lead of your oscilloscope is connected to mains ground. The casing of the PSU and the output ground is also connected to mains ground. So the scope ground clip is connected to the negative output of the PSU, and you will short out the PSU if you try to connect the scope ground clip to any of the PSU outputs.
Inducktion
Thu Feb 17 2011, 12:00AM
Is there any way to fix it?
Thu Feb 17 2011, 03:06AM
Anders M. wrote ...
Wait! Im confused, Ive always seen the ATX case as Ground to third prong mains, the black wires to the mainboard are not ground, but really the negative pole ( really a zero V ), for the various other positive voltages. the oscilloscope thus should not be shield probe connected to the Black ATX wires.
Thus, the ATX case, is not equivelent to its own Black wires.
Maybe you could tie the black wires and ATX case together then you would lose isolation safety from the mains, but gain a measureable circuit path.
is this what you meant Anders, or am i totally psychotic?
dmg
Thu Feb 17 2011, 03:21AM
I havent touched a PC powersupply in years.. let alone any of the ATXs.
IIRC some of the outputs are split rail (+V, 0V, -V). you should note that a negative voltage is not the same thing as a zero potential ground.
Im pretty sure the common ground for all these sources (be it +/-) would be chasis bonded, and mains grounded. most PSU's ive gutted had a little lug on the side of the box attached to mains ground, and the common grounding on the board itself connected to that.
Thu Feb 17 2011, 06:15AM
that little green screw lug is attached, from the mains side, not the lower V isolated side.
And yes there would be: (120 Vin: L,N,G) then isolation through magnetics, to (low Vout: -V, Black @ 0V, +V)
Thu Feb 17 2011, 09:57AM
Patrick wrote ...
In every ATX PSU I've poked around, the black wires are connected to the case and the third prong of the power cord. This used to cause me trouble with ground loops in my old home recording setup.
Nicko
Thu Feb 17 2011, 10:24AM
Steve McConner wrote ...
Patrick wrote ...
Seconded - just checked about 10 ATX PSUs I have here from HP, Compaq, Qtech etc. & all have COM connected to chassis & mains earth.
Adam Munich
Thu Feb 17 2011, 11:40AM
I suppose it might possible to use a cheater plug and float the scope's ground...
