  • Guests: 47
09/13 WarrenR (64)
09/13 currentkills91 (32)
09/14 Proud Mary (62)
Giant toroids
Microwatt
Tue Feb 15 2011, 06:29PM Print
Microwatt Registered Member #3282 Joined: Wed Oct 06 2010, 05:01PM
has anybody ever thought about buying a huge truck inner tube off of ebay inflating it and painting it with conductive paint or aluminum foil tape? these iner tubes are huge and very cheap you could make one for a total cost of 80 dollars including the cost of the paint. megavolt ES charges are within possibilty
Dr. ISOTOP
Tue Feb 15 2011, 06:46PM
I remember tesladownunder doing something using an inner tube covered with chicken wire, but the resulting corona ate away the rubber frown
Microwatt
Tue Feb 15 2011, 06:47PM
hence painting it with silver or foil.
Tue Feb 15 2011, 07:52PM
Martin King Registered Member #3040 Joined: Tue Jul 27 2010, 03:15PM
It's been discussed here :-
Martin.
Tue Feb 15 2011, 08:26PM
Read the above thread. Heres my idea, use expanding polyurethane foam the 2 part one, then fill through the shrader vlave (by removing it) the let it expand to inflate the tube, when its fully cured, cut the rubber tube off.
poof...instant light weight large toriod, cover surface to be conductive.
Microwatt
Tue Feb 15 2011, 10:05PM
foam is expensive why not papermache the thing
Wed Feb 16 2011, 07:04PM
The largest toroid I've ever made was 4" aluminium ducting around a bicycle wheel - works great but looks a bit odd.
