  • Guests: 44
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Flashover voltage for normal resistors
AleSeg
Wed Feb 16 2011, 03:52PM Print
AleSeg Registered Member #2727 Joined: Tue Mar 09 2010, 02:39PM
Hello all.
I want to know the flashover voltage in air for normal carbon resistors of high ohmic values as used in electronic circuits, from 1 / 4 W, 1 / 2 W, etc. (through hole resistors, no surface mounting).
Is difficult to find this data.
Does it change much this voltage if the resistance is immersed in an insulating medium such as vegetable oil?
Thank you very much
Wed Feb 16 2011, 04:23PM
youwont be able to find this type of data. you should run your own experiments with a NST + Variac, then destroy some resistors. also, the resistance will change a great deal (additional sintering) as the flashover voltage is typically 10-15 times greater then the spec'ed max voltage. beware if you series to many youll get other problems too.
flashover is typically not important to know, other limiting factors are.
If our search function here on the forum were not so shitty, i could have found my thread for you, but i have class now.
Wed Feb 16 2011, 06:30PM
The regular 1/4W type, only about 250-500V. 250 is usually what it says on the datasheet. They mean it, I have had them break down and destroy my tube amp circuits.
Wed Feb 16 2011, 06:32PM
Steve McConner wrote ...
whats spec'ed and what they will flashover at are two completely different questions.
And yes, I too would say they self-destruct quite easily, taking other circuitry with them.
Wed Feb 16 2011, 06:45PM
The actual flashover voltage varies with humidity and even more with contamination.
For a quick estimate look up datasheets for similar devices !
Then there's the question of safety, if this is for a Marx etc. then a fault will not harm you, if it's for a meter etc. then you don't want to be at the end of a chain of resistors that may flash over and connect you to eht.
If you thoroughly clean the resistors (e.g. wash with alcohol) and immerse them in oil the voltage rating will increase massively (>10x) to the point that dissipation will probably be the limiting factor. Potting in epoxy, resin, wax etc. also increases voltage ratings.
AleSeg
Wed Feb 16 2011, 07:55PM
Thank you for your answers.
I know what to expect working with HV.
I´m going to make a 100 chain resistors to measure almost 50 kV, but I will be looking at the voltmeter at a very prudent distance while the circuit are energized.
And I know about the five golden rules about working with voltage.
Anyways, I'll test some resistors, to verify the they can stand the voltage.
Can anyone give me a reference PDF for common resistors ?
See you, and thanx again
Wed Feb 16 2011, 09:01PM
I have had sparks jumping across a 0.6 watt resistor, might have been good 5kV and the resistance was still the same after the "test", though I don't remember the resistance value...
Wed Feb 16 2011, 09:17PM
These Link2 Link2 and these Link2 Link2
are my favourites for hv.
AleSeg
Wed Feb 16 2011, 09:40PM
Thank you for the links and for the quick answering :)
See You
