  • Guests: 64
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
stacking transistors
Microwatt
Tue Feb 15 2011, 04:40AM Print
Microwatt Registered Member #3282 Joined: Wed Oct 06 2010, 05:01PM
i would like to use mosfets to switch marx generators can you put the collector and emitter in series? such as 10 1200v in series?
Dr. ISOTOP
Tue Feb 15 2011, 04:43AM
MOSFETS aren't going to be able to handle a Marx's peak currents.
Tue Feb 15 2011, 05:08AM
Microwatt wrote ...
Yes. There are methods to do that. But honestly I think a Marx will kill anything you build along these lines. I think you'll massacre more transistors than you can afford.
cedric
Tue Feb 15 2011, 03:12PM
cedric Registered Member #2941 Joined: Fri Jun 25 2010, 08:08AM
bwang wrote ...
paralleled mosfet might ,as for the current ,it can be control by the load..
Tue Feb 15 2011, 04:15PM
Marx generator using power mosfets
Jiang, W.; Diao, W.; Wang, X.;
Pulsed Power Conference, 2009. PPC '09. IEEE
Abstract
A compact Marx generator has been developed by using power MOSFETs as the switches. The objective is to develop repetitive, compact, efficient, short-pulse, high-voltage generator for industrial applications. The initial tests were carried out by using 16 switches, achieving output of ~ 10 kV and ~ 250 ns in pulse width at repetition rate of ~ 400 Hz.
