  • Guests: 59
Arjan EMM (52)
01/01 Bosko (56)
01/01 hen918 (30)
01/01 Yuri_Ivanov (35)
Remote control pulse controlled via Voltage, any suggestions?
Ken M.
Fri Feb 11 2011, 07:21PM Print
Wanting to take a brake from the SSTC control module design and programming that I was working, I wanted to try and finish a Quad-copter project I had started last year but somewhat gave up on due to issues, also while reading hack a day today I came across this article
and it made me think sure a lot of quad copters are out there and most are simply some hobby gyros and V-tail splitters, then there are the micro-controller based ones that use gyros and accelerometers to control the stability, so I was thinking why not try and be cray and see about making a quad be stabilized via a 3 axis gyro and a 3 axis accelerometer without the use of a uC.
The thing is I'm not certain on how to produce the 1ms-2ms on time pulse that is needed to control the speed controllers and have it be controlled via the analog signals coming from the accel and gyros, I was thinking a VCO but I'm not sure that it would adjust the duty cycle instead of the frequency.
Right now this is all just an idea, and theory but I think it would be kind of cool to make something like this and not use a uC.
Any suggestions on producing a voltage controlled duty cycle from 1-2ms on time?
Bjørn
Fri Feb 11 2011, 07:59PM
You need to have a look at control theory Link2 or you will depend on luck and lots of money to replace all the broken bits. Most simple ideas will be prone to bad oscillations that will end up in a crash with 100% certainty.
The exact same theory works on digital and analog so you are not saving any work or money by doing it the analog way, most likely the other way around. If you used tubes then you could claim EMP resistance, if not then you get all the drawbacks of analog with nothing to gain except the oddity of lagging behind by 30 years.
mnr
Fri Feb 11 2011, 10:45PM
mnr Registered Member #996 Joined: Sun Sept 09 2007, 06:17PM
Generate a triangular or sawtooth wave (doesn't matter - as long as it's linear) of the appropriate frequency and feed it into a comparator, comparing it with your reference voltage signal. Whenever the reference is higher than the linear waveform, the output of the comparator will be your "on" pulse. I did something similar in the controller/feedback loop of a boost converter for a school project using a few op-amps.
Ken M.
Sat Feb 12 2011, 07:09PM
Thanks Bjorn for pointing me towards the control theory link, I knew of control theory and am using a form of dynamic control for it, I was just trying to think of a way for the gyros and accelerometers to generate a signal that the motor controls could understand, and yes I figured it would be more costly since I'd have to purchase all the parts to perform the control functions and to incorporate the human interface.
I was just thinking about it as more of a off the beaten path and to have a bit more of a challenge, rather then just plugging all the sensors and human interface into a chip and having a single code do all the work, even though I still probably am just going to use the uC just because I already have it and I knew he code, I'd just have to work on the pid loops and adjust the mixing algorithm.
MNr, thanks for reminding me of the comparator method, I kept thinking I had to use a specialized chip.
