  • Guests: 40
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Help req _how do I surpress arcs in a reed swicth
JamesH
Fri Feb 11 2011, 11:10AM Print
JamesH Registered Member #579 Joined: Mon Mar 12 2007, 09:45AM
I am building a demo involving a reed switch and an inductive load
I think the normal suppression of the arcing ( as in a relay) is done with a diode and a cap
I have tried a diode on its own , then added a cap but do not seem to be able to suppress the blue flashes inside the glass envelope,
Should I increase the cap size ( 1uF at the moment), decrease it , or am I completely wrong as usual.
The supply load is 12-20 v
later the demo will show the reed switch is replaced by a coil and transistor - so , at this stage I do not want to change the reed switch
Bjørn
Fri Feb 11 2011, 11:37AM
Why not turn the arcing to your advantage and use it to demonstrate one of the problems with mechanical switches?
3l3ctrici7y
Fri Feb 11 2011, 11:41AM
3l3ctrici7y Registered Member #1806 Joined: Sun Nov 09 2008, 04:58AM
Transient voltage suppression is usually done at the load, not the switch.
Place a diode in reverse bias across the inductive load.
A cap across the load will also suppress arcing in the switch when it is opened, but the cap will delay the power-off of the inductive load, and when you power it on, you will get a significant current through the switch contacts because the cap looks like a short circuit when you first apply voltage to it.
ConKbot of Doom
Tue Feb 15 2011, 12:28PM
Would it be cheating to use a SPDT reed switch and a 9v battery to run a mosfet? I.E. use the switch to drive the gate to either ground, or +9v. The battery should last for long enough. You'd still need tame any kick enough to not damage the mosfet, but you wont have to deal with an arc on turn-on like the reed would if you used a cap across the load.
James
Tue Feb 22 2011, 12:44AM
I would try a capacitor across the switch. It works with points in old fashioned ignition systems, if anybody remembers those.
radiotech
Tue Feb 22 2011, 04:24AM
For any 24 volt DC relay that can be handled by a given reed
switch, the method is a capacitor in series with a resistor across
the contacts. This is called a snubber and there is reams of
info on the net under relay engineering.
