  • Guests: 53
marks aerosol generator
Microwatt
Fri Feb 11 2011, 05:14AM Print
Microwatt Registered Member #3282 Joined: Wed Oct 06 2010, 05:01PM
I have seen this on patents and stuff. Seems like an interesting way to make high voltage. anybody know why it has not been implemeted in a\ny fashion?
Dr. ISOTOP
Fri Feb 11 2011, 06:57AM
Link to the patent?
Microwatt
Fri Feb 11 2011, 07:16AM
here
This seems like some sort of long lost technology. the article says 3000v 1uA turns into 50kv 200uA with just a spray of water. This could be scaled up to make millions of volts from our ZVS flybacks.
Turkey9
Fri Feb 11 2011, 07:41AM
Oh look another free energy machine. It outputs over 16 times the voltage and 200 times the current input. Even if there were some static charge buildup, it would not be nearly this large. Reading the article, it seems like they are saying heat is converted to power through some strange bending of the laws of physics. Knowing how Popular Science writers take real science and distort it to seem more amazing than it is, I wouldn't be surprised if the device was originally just a setup to experiment with static charges.
P.S. I'm betting this thread will be locked by admins before long.
Ash Small
Fri Feb 11 2011, 07:57AM
This appears to have been patented:
I've not read enough yet to really know what it is about.
EDIT: Apparently the principle is here:
EDIT 2: Patents etc. are here:
EDIT 3: Apparently it is not 'free energy' but it needs a source of heat as well. It converts the heat energy into electricity, alledgedly.
They say it can be used to convert the heat going up your chimney into electricity.
EDIT 4: I still can't see how it works, though.
QUOTE: "Will it work? “We’re sure of it”, Mark says. “We’re not sure of the power output, but it will be from one to 10,000 watts --- we’re hoping for 10,000”. "
hboy007
Fri Feb 11 2011, 11:07AM
I assume you can imagine the working principle as a Van-De-Graaf generator except that the conveyor is no longer a rubber belt but a stream of droplets. The actual work is done by the compressed air. I see no free energy mumbo-jumbo in this.
Antonio
Fri Feb 11 2011, 01:45PM
Just an electrostatic induction generator. Surely works, but with the problems of all electrostatic generators: Too small power for the size of the device, too high output voltage, and extremely high insulation required.
See this:
Adam Munich
Sat Feb 12 2011, 12:33AM
That was really interesting. I definitely need to try this...
Edt: vidyo of one. Link2
Xray
Sun Feb 13 2011, 02:33AM
Xray Registered Member #3429 Joined: Sun Nov 21 2010, 02:04AM
Microwatt wrote ...
There are much simpler and more efficient ways to generate high voltage. The article ignores the fact that it requires POWER to compress air, and it requires POWER to supply the bias voltage needed to charge the water vapor. The amount of power needed to drive this device is much more than the electrical power you can generate with it. It's not really a "long forgotten technology" but rather a laboratory experiment that wasn't worth much to anyone. That's why it was forgotten! cheesey
Microwatt
Sun Feb 13 2011, 08:20AM
Xray wrote ...
Microwatt wrote ...
yea but after you bias the power gird you could feedback to voltage from the output back in and get increasingly high voltages. ala kelvin water dropper. i am sure that 1 million volts is easy to make with this. who wouldn't want 4 foot sparks in thier garage?
