  • Guests: 49
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
TL494 and 5kV power supply
Thomas F
Thu Feb 10 2011, 03:18PM Print
Thomas F Registered Member #503 Joined: Sun Nov 19 2006, 06:37PM
Hi ,
I am trying to make a 0~5kV variable PS using the TL494. I have attached the schematic in case someone wants to help me out.
The problem I am facing is that,the control is not linear but jerky.Like it shows 4.5kV and then falls down to 3.kV.The voltage also keeps jumping about below 1kV. Is there any error in my circuit ?
I am using 30kHz and set the maximum duty cycle to 20%,since the load is an open circuit except for the feedback divider.Since I need only one feedback loop,I have paralleled the two comparators ( is this ok ?).
In one of the circuits on our website I have seen that the INV pins of the feedback opamps is directed shorted to the
Feedback pin.But the circuits in the appnotes do it through a 51k resistor.What is the right method ?
Thanks
Thomas
1297351068 503 FT0 Tl494
Thomas F
Tue Feb 22 2011, 01:47PM
Hi,
Well I managed to get it working as wanted. The glaring error I had made was using a 0~5V as my set point.The TL494 saturates above 3.5V as per the TI appnote.I modified to work at 0~2.5V and now it behaves as wanted.
Also I reduced the 100M in my feedback divider to 10M(1Mx10 chain),which also makes a big improvement.
Thanks
Thomas
1298382356 503 FT108317 Tl494 V2
