  • Guests: 59
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
4HV Terminology Database
ScotchTapeLord
Wed Feb 09 2011, 12:03AM Print
Hello all,
I am working on getting a website together and I started a list of common terms that we throw around like everyday jargon that would have the common folk a'droolin, so that new and less experienced members can have a sort of guide to our technical slang.
It's in its early stage and needs your suggestions.
Adam Munich
Wed Feb 09 2011, 01:15AM
MOI = Fancy new microwave oven inverters.
Assload = 1.152kW
Hollow State = Containing nothing but vacuum tubes.
3l3ctrici7y
Wed Feb 09 2011, 09:47AM
3l3ctrici7y Registered Member #1806 Joined: Sun Nov 09 2008, 04:58AM
I thought assload was equal to 1.21 GW ;)
I think that since it was a single event, Joule would have been a better unit.
Wed Feb 09 2011, 09:58AM
MOT- Microwave oven transformer, shunted, yet not current-limited step up transformers that put out about 2kV
MOT output is current-limited by means of magnetic shunts, though this limiting is not intended to withstand short circuits, as we find, for example only, in the older, non-electronic NSTs.
OBT- Oil burner transformer, they put out a few kV to ignite an oil-burner, and are not meant for continuous use
In Europe, at least, modern type-approved OBTs commonly have outputs from 2.5kV-0-2.5kV to 6kV-0-6kV with the centre tap taken to Earth. Some - but not all - OBTs are rated for continuous operation. Electronic OBTs are available with outputs of 2 x 12kV. While the great majority of OBTs have an earthed centre tap, single ended types are still available. Gas Burner Transformers resemble OBTs in most respects, but are usually single ended and typically have RMS outputs from 8kV - 10kV, with electronic types producing as much as 15kV.
LOPT/FBT- Flyback transformer, high frequency transformers that operate on pulsed DC, rated between 20kV and 30kV and 1mA on the output, can be AC or have internal rectifiers
Modern so-called 'Diode split' Line Output Transformers are commonly available in the range 18kV - 32kV. Older LOPTs intended for use with an external solid state doubler or tripler typically had AC outputs of 6kV - 10kV. Vintage AC output LOPTs - designed before HV solid state diodes were generally available - used a single thermionic diode as half-wave rectifier. As multiplication with thermionic diodes was not practicable because of the difficulty of providing floating filament supplies economically, these early LOPTs had to produce the full CRT anode voltage, and so can be expected to produce a considerably higher voltage than the later AC LOPTs designed to work into a doubler or tripler.
Iggy/Ignition Coil- these autotransformers come out of vehicles and are used to ignite the gasoline in a combustion engine
'Traditional' vehicular ignition coils have both a primary and a secondary winding, with the cold end of each taken to a common Earth. They are not autotransformers.
ScotchTapeLord
Wed Feb 09 2011, 01:35PM
Thank you for your corrections and contributions.
I will make modifications to the main list.
Thank you for the specific numbers, Mary, I guess I should have written "about 20kV to 30kV" or stated that there is a +/-2kV tolerance on all my values, but I shall put in the new numbers and try to condense your details into something more noob friendly (their eyes get tired after two lines).
Just trying to keep things simple and basic, but that does not mean incorrect. Keep the information coming.
Wed Feb 09 2011, 02:10PM
On reflection, I'd revise the voltage range of 'diode split' LOPTs in the downward direction to 17kV - and perhaps lower for miniature portable monochrome sets - and in the upward direction to 33kV for some large colour CRTs.
But you should consult an expert for a definitive view. I know only a little more about LOPTs than would a hippopotamus.
Wed Feb 09 2011, 04:59PM
Just to note: A forum thread is not a database. In 6 months time it'll be gone and forgotten. You all know how good the forum search function is. tongue But try typing any of the jargon terms mentioned into my custom 4hv search engine linked below, and you'll see there is already lots of info for each one.
This sort of thing should go in the HVWiki, if it isn't there already. Try searching it. I don't know if Chris has fixed the problem that caused registrations to be closed.
Oil burner ignition transformers are OBITs.
ScotchTapeLord
Wed Feb 09 2011, 05:44PM
The thread was just wanted feedback and contributions. It would probably make a good addition to the wiki, but I was going to publish it on my site, first. As for the search function, of course there is a lot of information available, but I thought it would be good to have a centralized location with general information for quick reference that people can add to. A dictionary of sorts.
