  • Guests: 52
Protecting O-scope inputs from HV transients...
Fri Feb 04 2011, 12:30AM Print
Since i did not want to skyjack this thread any further " Link2 " I started this one...
Here is where we left off...
Anders M. wrote ...
Patrick wrote ...
Anders M. wrote ...
Patrick, a neon lamp would be excellent here, as long as what you are protecting can stand voltages up to the breakdown voltage of the neon lamp. With a scope, this shouldn't be a problem.
What if I had a 600 Mohm resistor running as a V divider into an oscope, if I wanted to clamp the BNC input at 30 V pk could I use a 72v neon a little higher up on the divider to achieve the 72v, and 30v numbers simultaneously?
With such high impedance (600M) I worry about leakage current a several microamp leak would be perhaps a 10% error. (Hence the desire to avoid zener or TVS's)
Is my reasoning sound? Didnt mean to HiJack this thread, but it is related.
Yeah, if I understand you right, the resistor divider idea should work for getting it to clamp at 30V with a neon lamp, if you put the voltage divider after the neon lamp.
You're right, TVSes wouldn't be much good here, as 30V ones have typical leakage currents of around 5µA according to datasheets.
I found some good news. According to this site Link2 as Resistor , the typical resistance of a neon lamp is in the hundreds of gigaohms range, probably with a lot of variation from lamp to lamp.
I have run the following sim, and will use these screen caps to illustrate.
1296779400 2431 FT0 Neon1a
I want the 30kV wave not to be clipped at the BNC.
1296779400 2431 FT0 Neon1b
I want the clipping to begin at about 33-35 kV. 40kV applied, clipping definately taking place.
1296779400 2431 FT0 Neon1c
Here we see 40 KV applied with the pseudo-neon left open, such that the divider in now unhindered, scope unprotected. (22.5 V - 28.2v = -5.7 V)
So -5.7V of clipping is added to 28.2V to get the wave of 22.5V.
I think I have done all this right, please comment.
Pinky's Brain
Fri Feb 04 2011, 02:39PM
The problem with airgaps is that they are pretty slow.
Also, why use tubes? Surge arrestors cost next to nothing.
Fri Feb 04 2011, 03:40PM
Pinky's Brain wrote ...
Are surge arrestors not tube components ? Surely you dont mean MOV's or TVS's !
Pinky's Brain
Fri Feb 04 2011, 03:59PM
Well they are ceramic cylinders, so in that respect they are tubes ... just purpose built to arrest surges as opposed to making light.
James
Fri Feb 04 2011, 04:49PM
For serious HV stuff an old vacuum tube oscilloscope is not a bad idea. I keep my ancient Tek 531 around for such things. It's huge, heavy, and makes a good space heater but I don't have to worry about frying it with HV.
Fri Feb 04 2011, 06:12PM
Gas tube surge arrestor....
]littelfuse-src_gdt_cg-cg2.pdf[/file]
Anders an I were discussing the possibility of Neon tubes, that diode was only used because Multisim10 doesnt seen to have NE-2 in its component selection. There is no air gap either.
Pinky's Brain
Sat Feb 05 2011, 01:05AM
Air gap, neon gap, nitrogen gap ... all the same, all relatively slow.
Sat Feb 05 2011, 05:05AM
Shit! really?! Give me an estimate of "slow" please.
Myke
Sat Feb 05 2011, 08:43AM
I measured the fall time of the IN-3 neon lamp striking at 80V to be about 2.5µs. The fall time for higher voltage neons might be lower though. Normal neons are pretty slow. RC relaxation oscillators with them have a max frequency of about 100kHz. At that frequency, the change in the voltage across the neon is only a couple of volts or so.
Sat Feb 05 2011, 06:19PM
Most scopes have a maximum peak input voltage of several times above the "max" input it says on the scope input. For example, the Rigol DS1052E which many members of 4hv have is CAT I rated to withstand 1000Vpk on the inputs. This means that even "slow" clamping devices should be fine, as long as you don't measure a source with ultra fast rise time, like a marx.
