  • Guests: 48
New can crusher coil
Microwatt
Wed Feb 09 2011, 05:58AM Print
Microwatt Registered Member #3282 Joined: Wed Oct 06 2010, 05:01PM
There is not a single reason why you can't crush a can with only 100 or less joules of power. why not consider machining a single turn coil from copper or aluminum. a coil such as this could stand up to 100KJ and crush rolls of quarters at a time.
1297230444 3282 FT0 Ring
Xray
Wed Feb 09 2011, 06:08AM
Xray Registered Member #3429 Joined: Sun Nov 21 2010, 02:04AM
Microwatt wrote ...
Actually there are LOTS of reasons why you might not be able to crush a can with only 100 joules of power. But if everything is designed correctly, then it should work.
As for your one-turn coil for crushing rolls of quarters, copper would definately work much better than aluminum, but it would probably take a few megajoules of energy to do it. The geometry of a single turn coil would not allow you to crush an entire roll at once. You might be able to crush two quarters at a time, but that would be about the maximum in my opinion.
Wed Feb 09 2011, 06:36AM
What if his copper cylinder billet is 3 inches tall, with the plan form he shows above? Would roll shrinking be possible, given a few megajoules?
Xray
Wed Feb 09 2011, 06:01PM
Patrick wrote ...
Interesting concept! I personally do not have the math expertise to work out the Maxwell equations, but if someone wanted to try it "by the seat of their pants", it would make for an interesting (and explosive) experiment! Most hobbyists probably couldn't afford the huge pulse capacitors that would be required to shrink a roll of quarters. And keep in mind that when you "shrink" a quarter (or any other coin for that matter) the result will be that you will make it thicker. You never lose any mass, you only change its shape. So if the diameter of the roll gets smaller, then its length will proportionately get longer. The real trick would be to mechanically hold the roll of quarters together so that they don't explosively fly out of the shrinker coil assembly before they had time to get shrunk.
Wed Feb 09 2011, 06:12PM
Xray wrote ...
Agreed.
Microwatt
Wed Feb 09 2011, 08:43PM
machine a slight concave shape into the center face. this will stabiize the lorenz forces. a solid coil like this can be reused again and agian becuase it will not destroy itself.
1297284182 3282 FT108222 Side
Wed Feb 09 2011, 11:09PM
I dont know about being self-destructive resistence, it may fly apart all the same. Theres a lot of force running through that hole in the middle. Also, by some 0.75" polycarb, use it to tie your bolted ends together, I have a bad feeling that a nice ring like yours will open up like a "C" shape.
Wed Feb 09 2011, 11:33PM
Interesting thought, but there's nothing magic about 1 turn. Electromagnet coils can be rewound to trade off voltage for current, to match the power source. For example, suppose your coil were replaced with a 10-turn Bitter coil in the same volume:
1297292604 2099 FT108222 Uw Crusher
With 10 times the voltage and 1/10 of the current, it would produce the same magnetic effects with the same input energy and power. Actually better, because the field distortion at the gazin and gazout connections is limited to the ends of the solenoid. The new V and I values would be more practical for making the pulse-discharge capacitor, switch, and connecting wires.
At lower energy levels, a 1-turn coil might be a good match in a can crusher using electrolytic capacitors (relatively low voltage and high capacitance). To get the most out of 1 turn, the interconnection loop between capacitors, switch, and coil should be geometrically compact and arranged to minimize its inductance.
As for being obviously strong enough to crush a roll of quarters without being damaged, I don't think so (whether 1 turn or 10). The radial pressure on work coil is no less than on the workpiece. Quarters are made with hard steel dies, and are work-hardened in the process.
Show us the numbers. 100 kJ can [edit] heat about 270 grams of copper to its melting point.
Microwatt
Thu Feb 10 2011, 12:48AM
but you are missing a point here is that the machined coil will beat any wire wound coil in mechanical strength tests. your bittur coil windings will seperate and reduce the induction on the piece. with this ring enclosed inside a polycarbonate ring. I am sure I won;t end up with a C clamp!
1297298848 3282 FT108222 Nwring
Thu Feb 10 2011, 01:13AM
Klugesmith wrote ...
[edit again] As xray said, coin shrinking doesn't reduce the volume of the workpiece. To reduce the diameter of a stacked roll of quarters, its length must increase by the square of the diameter ratio. You're putting huge demands on the strength of the coil material. And since the work is done in microseconds, I guess the inertial resistance will be significant even with strong materials. Hypothetically, if the electromagnetic forces were much stronger than the yield strength of coil and work bar, conservation of momentum and minimization of kinetic energy suggest a solution where thick coil expands radially at low velocity while work bar extrudes axially at high velocity.
Yeah, what Klugesmith says.
But I think you should try all this anyway, as kinetic explosions are so dam fun.
