  • Guests: 56
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
Killed my meter (again)
Adam Munich
Wed Feb 02 2011, 04:34AM Print
Ugh, so I'm not going to buy any more expensive multimeters. I'll stick with the $3 cheap ones, and i f I need a true RMS reading I'll just use my scope. I do need a method of testing capacitance though, so I found this on egay. Link2
It's an LC meter, supposedly capable of the following,
Measurement accuracy:1%
Capacitance measuring range: 0.01 pF - 10uF minimum resolution 0.01 pF
Big Capacitance measuring range 1uF-100mF minimum resolution:0.01UF
Inductance measuring range: 0.001 uH - 100mH minimum resolution 0.001uH
Big inductance measuring range: 0.001 mH - 100H minimum resolution 0.001mH
Test frequency range: L/C about 500KHZ/Big inductance 500HZ
Effective display digits: 4 digits
So... does anyone know if this this thing legit? I've never had an L meter and it would be very useful if I start doing radio circuits.
Wed Feb 02 2011, 05:22AM
I had a BK Precision 875B ($299 years ago), LCR would measure down to 0.001ohms, 200pf and 2uH, it was great very useful saves me from guessing and calculating, I mean youd pick it up and poof theres your answer. But there sensitive, Id look at BK and fluke and others. Spec them out for function versus cost, 0.01pf sounds suspicous both my old BK and new no-name have trouble with 0.0 up to 3.0 pF not being steady and flickering alot, so that 0.01pF sounds like crap.
get one it will save you trouble and pain later. cant speek to the one which you site though.
Adam Munich
Wed Feb 02 2011, 05:28AM
Yeah I figured that sounded fishy, but 5pf resolution is good enough for radio stuff. I'll look around, but $50 is kind of my maximum budget.
Wed Feb 02 2011, 05:42AM
yeah well I got a no-name china one for 69$ only does C though, as I blew out my BK when I measured a electrolytic cap that was totally discharged, then I removed the resistor, waited a minute to do some set up... then measured it and SNAP!!! a spark (it self recovered a slight bit) and the meter never worked on any range ever again not r -c or l. Bricked the dam thing.
Wed Feb 02 2011, 06:05AM
hah, i fried a meter once like that.
Figured that the energy stored in a bottle capacitor once shorted was nil, so was safe to measure a few seconds later. BAD move.
Strangely enough the frequency range still worked...
Then there was the meter a friend toasted the resistance range on by trying to measure the impedance on a CB but not realising you were supposed to have it unpowered.
-A
Matt Edwards
Wed Feb 02 2011, 06:12AM
Matt Edwards Registered Member #2838 Joined: Fri Apr 30 2010, 07:55PM
That sucks dude! I always check with my $3 meter first when I am unsure. I killed two good meters before I started doing that... Now it is a must!
Adam Munich
Wed Feb 02 2011, 06:22AM
Hmm, same item only a couple bux cheaper. This listing also gives some realistic accuracy values and some pictures.
Nicko
Wed Feb 02 2011, 07:02AM
Grenadier wrote ...
We've been looking at this very item on one of the UK audio forums - one of the guys got one and compared it against his Fluke - it came out pretty well (within a few %). There are a couple of versions available, including an "enhanced range" one...
Wed Feb 02 2011, 09:00AM
Grenadier wrote ...
I think it's a knock-off or derivative of this product, which was a project published in a EE magazine almost 20 years ago. Link2 They all use a microcontroller to measure the frequency of an internal LC oscillator before and after adding the unknown L or C. Here's another knock-off showing the schematic: Link2
You can get the same accuracy more cheaply, if not more conveniently, by building just the oscillator with LM311, reference L and C, and a few resistors. Measure the frequency with DVM or other instrument of your choice, before & after switching in the unknown. Do the calculation on your computer.
Real inductors, esp. with ferrous cores, and to a lesser extent capacitors have significantly non-ideal behavior. The "correct" L value depends on frequency and amplitude, neither of which is fixed in these cheapie "meters".
These are not in the same class as "real" LCR meters, which have a defined sinusoidal stimulus frequency and amplitude, measure the response amplitude and phase, and report L+R or C+R or vector impedance at the given excitation condition.
But the guy I take to be the "inventor" reports excellent accuracy in measuring high quality standard inductors & capacitors, as summarized at the bottom of Link2
Nicko
Wed Feb 02 2011, 10:02AM
Klugesmith wrote ...
Grenadier wrote ...
I think it's a knock-off or derivative of this product, ...
The basic principle has been around forever - applying a uP to it and a budget price is what's different.
Main issue is that the OP mentions radio circuits - there is no "Q" measurement from these cheapo devices, and measurement is (typically) at a fixed, fairly low, frequency. You also have potential issues in zeroing and measurement of small (if doing RF) inductors & caps. They can also be confused by some boundary conditions and easily damaged if you forget to discharge caps before testing.
For general workshop day-to-day stuff, I use a Peak Electronics Atlas LCR (available in the USA too) Link2 - this is a great device and the company provide excellent after-sales service (re-cal etc.). Nice people. I have their DCA (component analyzer) too - life saver when dealing with odd SMDs Link2
Cheers
