  • Guests: 23
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
Silicon Carbide MOSFET's
Mon Jan 31 2011, 03:14PM Print
Martin King Registered Member #3040 Joined: Tue Jul 27 2010, 03:15PM
Interesting Link2 Link2 Hmmm They left "Tesla coil drivers" off the applications list!
Martin.
Mattski
Mon Jan 31 2011, 04:45PM
Looks like they're already in stock at Digikey for $93.75!
Tue Feb 01 2011, 12:59AM
I would love to have these, but dam expensive.
Tue Feb 01 2011, 01:21AM
Me too! Lookee here! smile
Silicon carbide for high resolution X-ray detectors operating up to 100°C
Giuseppe Bertuccio, Roberto Casiraghi Antonio Cetronio, Claudio Lanzieri and Filippo Nava
Nuclear Instruments and Methods in Physics Research Section A: Accelerators, Spectrometers, Detectors and Associated Equipment
Volume 522, Issue 3, 21 April 2004, Pages 413-419
Abstract
This work presents experimental results on the possibility of high resolution X-ray spectroscopy in a wide temperature range, from room temperature up to 100°C without any cooling system, using Silicon Carbide (SiC) detectors. This capability arises from the very low noise of SiC detectors at high temperature because of their extremely low-leakage current density (20 pA/cm2 at 24°C and 1 nA/cm2 at 107°C with mean electric fields of 120 kV/cm). Spectra of 241Am acquired by a pixel SiC detector are reported with equivalent noise energies of 315 eV FWHM at 27°C and 797 eV FWHM at 100°C. The contributions of the different noise sources of the detector and of the front-end electronics are determined and analyzed. The potential for SiC X-ray detectors and open issues in SiC technology are highlighted.
rp181
Tue Feb 01 2011, 02:29AM
I interned at a lab that focused on this:
The equipment next to the fume hood is a VP508 CVD reactor. You can see the gas control cabinets in the very back that controlled nitrogen, argon, propane, and silane gas. The piece the guy is working at is a Residual Gas analyzer.
I did most of my work on graphene grown on SiC.
Heres a rather bad powerpoint I made at the end. Anyway, my point is the degradation as more and more steps were taken. I recall they made some demo schottky diodes a while back.
BTW, one if the slides mentions a textured surface. We later found out that this was actually not the surface, but the back of the wafer. Results were better once the SEM was lowered to 5kV.
]final_presentation.pdf[/file]
Wish i was allowed to take pictures, there was some cool stuff in that one lab, not to mention the entire Electronics division and the whole campus.
Tue Feb 01 2011, 04:16AM
Proud Mary wrote ...
Thats pretty cool, no expert on semi's, but I know these specs are gooooooood. Ive been waiting for these promised devices for more then 2 years! (mostly diodes and transistors) the spectra idea is all over my head as per usuall Proud Mary.
Tue Feb 01 2011, 09:41AM
Oh, cool. SiC power JFETs have been out for a while. Steve Ward and I looked at them, and we concluded that they were nothing special for DRSSTC work.
But they might be worth a try, the awesome new Cree MOSFETs may drive down the price of the old JFETs. smile
Adam Munich
Wed Feb 02 2011, 04:55AM
Heh, the sample button on cree's site leads me right to digikey. Dang. mistrust
Thu Feb 03 2011, 05:19PM
I've just ordered this inexpensive piece of SiC from an ebay seller in Poland.
It looks to be only semi-refined which is all to the good, as it may contain all sorts of interesting dopants.
1296752931 543 FT0 Sic
I'll try it with assorted cat's whiskers to start with - bronze, gold, and so on, in the way of the crystal and cat's whisker wireless sets of long ago.
My main interest is to use it for radiation detection experiments, but I'll give it a go as a demodulator for a bit of fun.
cedric
Thu Feb 03 2011, 05:48PM
cedric Registered Member #2941 Joined: Fri Jun 25 2010, 08:08AM
green led?
