  • Guests: 55
Does anyone know how Glassman "reversible polarity" HV power supplies work?
jpsmith123
Sun Jan 30 2011, 09:50PM Print
I'm assuming that a floating HV secondary winding drives dual half-wave, opposite polarity VM stacks; and to change the output polarity, two connections would have to be swapped. Is that how they do it?
Sun Jan 30 2011, 10:32PM
You have assumed - almost - right! smile
Here is the Spellman 1999 patent:
United States Patent 6002600
Reversible polarity high voltage power supply
Assignee: Spellman High Voltage Co. (Hauppauge, NY)
Mon Jan 31 2011, 01:21AM
Wow, an insulated electric-motor gear train, to rotate the whole potted VM.
jpsmith123
Mon Jan 31 2011, 02:00AM
I didn't think to look for a patent. Thanks for the link.
In taking a quick look at it though, it seems to me that some of the schematic diagrams are wrong. For example I don't see how the arrangement shown in Figs. 1B and 2 can work.
I thought I would see something like this:
1296439120 1321 FT107463 Stacked Vm
Mon Jan 31 2011, 05:05AM
Yes I do what you have drawn, reverse the direction of the diodes. but they show a mid point tap with no reversal of diodes. I wonder whether they ignore the lower half due to polarity? and that ground on the other side takes care of the rest.
Wolfram
Mon Jan 31 2011, 06:59AM
Patrick wrote ...
Both the lower half and the upper half contribute to the output voltage. Multipliers don't need the AC feed to enter at the bottom of the stack, I think feeding it from the middle of the stack results in an overall lower output impedance of the multiplier (but don't quote me on this), but the main disadvantage is that the coupling capacitor needs to stand off much more voltage than the rest of the caps, the full DC voltage at this stage in the multiplier plus the AC voltage.
Ash Small
Mon Jan 31 2011, 07:07AM
From the Glassman EW series instruction manual:
1296457659 3414 FT107463 Polarity Reversal
Also from the Glassman EW series manual:
1296458175 3414 FT107463 Polarity Reversal 2
1296458175 3414 FT107463 Polarity Reversal 3
[Edit: Double post...]
Mon Jan 31 2011, 08:53AM
jpsmith123 wrote ...
That is what is more or less being illustrated in Fig 1C - the "prior art" claimed to have been improved upon by this patent.
One should remember that the existence of the patent doesn't mean necessarily that Spellman have ever produced and sold the rotating C&W PSU.
Worth a look for its inventive electromechanical engineering is:
MODULAR CASCADED REVERSIBLE POLARITY ULTRAHIGH DC VOLTAGE SUPPLY SYSTEM
United States Patent 3643105
jpsmith123
Mon Jan 31 2011, 01:15PM
But Fig. 1C shows two separate, individually selectable transformer/multiplier units (btw note the error/omissions in this figure; i.e., both multipliers are shown having the same orientation of diode polarity, and no grounded terminals are shown). Whereas in the schematic I posted, the HV output is floating thus the polarity would be reversed by simply swapping the connections to the output terminals of the two multiplier stacks.
Proud Mary wrote ...
Mon Jan 31 2011, 01:23PM
Yes, there does seem to have been a drafting error in the patent 'prior art' diagram.
