  • Guests: 75
Protecting a CW Multiplier From Short Circuit Overcurrents
jpsmith123
Fri Feb 25 2011, 08:50PM Print
I'm wondering, does anyone happen to have a copy of the following paper? I'd really like to see the details of this study.
Rev. Sci. Instrum. 77, 045101 (2006); doi:10.1063/1.2188342 (6 pages)
Study on the short circuit transient process and overcurrent protection of Cockcroft-Walton high voltage power supply
Y. M. Zhang1, X. D. Su2, H. Su2, J. T. Liu2, H. Y. Lv2, and T. L. Su2
1Department of Modern Physics, Lanzhou University, Lanzhou 730000, China and Department of Physics, Pingdingshan University, Pingdingshan 467002, China 2Department of Modern Physics, Lanzhou University, Lanzhou 730000, China
(Received 25 October 2005; accepted 26 February 2006; published online 3 April 2006)
It has always been an important and difficult problem for the designer of an intense current Cockcroft-Walton high voltage power supply to quantitatively select appropriate protective resistance so that not only can the power supply be protected reliably once the high voltage output terminal is short circuited but also the negative influence of the protective resistors to the load characteristics of the power supply and the significant but unnecessary power loss on the protective resistors when the power supply runs normally may be reduced to a minimum. In this article, thorough analyses are made to the equivalent circuits in each stage of the short circuit transient process of Cockcroft-Walton circuit. The results indicate that in this process, significant overcurrent only occurs in the rectifiers situated in the locations of the highest and lowest potentials of the voltage multiplier, but there is no significant overvoltage in any component. In order to quantitatively estimate the most possible maximum ∫ 0∞i2(t)dt value of the rectifiers corresponding to a certain protective resistance, a simplified equivalent circuit based on some reasonable assumptions is given and some formulas, which may enough be reasonably used as a basis of quantitative estimation in engineering design, are deducted.
