  • Guests: 59
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
Science Fair Board
Arkin
Fri Jan 28 2011, 01:43PM Print
Arkin Registered Member #2140 Joined: Tue May 26 2009, 09:16PM
Local Science Fair is coming up, and here is my science fair board as of now, any suggestions?
Download for a large image (48x36, tri fold poster)
Mattski
Sat Jan 29 2011, 12:33AM
Some thoughts:
Under Materials you list "NRL" but we do not find out who they are until the conclusion, I would point that out in the start. If possible, use bullet points instead of dashes to look nicer.
Where you list the data of Mobility and Screw, and plot Mobility and Dislocation Density, you should keep consistent the naming consistent rather than changing from Screw to Dislocation Density. The font size on the excel plot should probably be increased. The data is also mislabeled in the plot, x axis looks like it should be mobility and y axis looks like dislocation density, either that or the table is flipped. And it would be nice to say somewhere what surface are this dislocation count is over, e.g. 10um^2.
Above that data you have 3 pictures, the last of which looks like an SEM, but I'm not sure what the other two are exactly. The last picture has a (c) as though there was a caption, but the first two have no letter.
Arkin
Sat Jan 29 2011, 05:03AM
Thanks for the feedback, I will fix it.
For the picture with the (c), that is just from the source, don't think it is part of anything. I'le see if I can remove it without too much "damage". The 1st pic is also a SEM, just a much larger area. The second is the same picture with contrast adjusted, and dislocations labeled.
