  • Guests: 46
seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
diode recovery
cedric
Wed Jan 26 2011, 11:45AM Print
cedric Registered Member #2941 Joined: Fri Jun 25 2010, 08:08AM
on the nanosecond scale, does diode have a forward recovery period?
hboy007
Wed Jan 26 2011, 12:18PM
forward recovery defines an inductive behaviour at turn-on. It is being attributed to parasitic inductivity but perhaps electron mobility limitations play a role here, too.
cedric
Wed Jan 26 2011, 01:19PM
cool ,thank you.
in those condition,what would be the behavior of the diode if the forward voltage rise above the rated breakdown voltage of the diode?
Pinky's Brain
Wed Jan 26 2011, 03:20PM
It won't, not with practical dA/dt values.
I've seen one paper which used a tapered stack of diodes in forward conduction for pulse sharpening but they started with a ns rise time to begin with.
PS. forward recovery is not purely inductive ... also fast recovery diodes actually have worse forward recovery.
cedric
Wed Jan 26 2011, 04:10PM
my concerns was about the possibilities to use the mosfet intrinsic diode to bypass the mosfet in case of negative pulse echo from a coax(we are talking about a mosfet base pulser on a coax load..)
some time the load can create harmonic with rise time of one or two ns .
Pinky's Brain
Wed Jan 26 2011, 06:29PM
Won't that reflect it right back again?
ScotchTapeLord
Wed Jan 26 2011, 06:47PM
Some MOSFETs have good diodes, some not so much. If the S-D voltage gets too high, the MOSFET can probably avalanche it but it could cause problems. If the diode's speed is slower than the FET's fall time, then you may want to consider an external diode and perhaps even isolation of the internal one.
If you can afford a bit more turn-on loss perhaps you should add a capacitor across the switch in the order of perhaps a couple dozen pF to help lower the harmonic spike. Or you could slow the turn-off time to perhaps a similar effect.
Pinky's Brain
Wed Jan 26 2011, 06:50PM
Forward recovery is not so much a question of speed, it's a question of duration and magnitude. Conduction is defacto instant, they just start at relatively high resistance (10s of ohm, with fast recovery diodes having a higher resistance that standard recovery diodes).
cedric
Thu Jan 27 2011, 11:18AM
it make sens...
pinky's do you have any reference about this paper you are talking about? (tapered stack of diodes in forward conduction for pulse sharpening) (out of curiosity..)
Pinky's Brain
Fri Jan 28 2011, 04:52PM
cedric wrote ...
it make sens...
My computer with a million randomly downloaded papers is momentarily down, I'll track it down next week.
