  • Guests: 83
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
Trouble routing a PCB
rp181
Sun Jan 23 2011, 11:51PM Print
I am having trouble routing these last signals on an XMOS board. The idea is to have a xmos module that can plug into base boards, like the gumstix. I primarily did this so I can have parallax strips with different sensor spacings, but it could easily be used for anything else. There are 2 SMD connectors on the bottom, one for JTAG and one for an 8 bit port, plus 4 1 bit ports. If someone could take a look at it, that would be great! Feel free to play with spacing and such.
I would like to keep it at 2 layers with 15mill vias (6/6 traces), as cost will be half!
]final_plan.zip[/file]
hboy007
Mon Jan 24 2011, 01:27AM
well, it can be done once you realize the possibility of tight spacings. Ah well, you will definitely have to tidy up a lot, too.
1295832468 1667 FT106982 Routed
rp181
Mon Jan 24 2011, 01:33AM
This is my first attempt at hand routing, so I expected trouble.
That looks great! Could you upload the eagle files?
EDIT: Looked at your changes, that will help in the future! Via's you added look too small (min hole size is .015"). Can you elaborate on the tidying up? I thought I did a pretty good job on the whole left side :)
hboy007
Mon Jan 24 2011, 11:25AM
yes, I saw that in the DRC but after an hour of routing I thought "what the ... am I doing right now?" and let it be. You can always sacrafice a bit of the restring in favour of a larger drill if it has to be. Mask alignment errors are not very likely to destroy the via at that point because the drill holes are filled.
Mon Jan 24 2011, 11:29AM
Isn't .015" just the default minimum hole size in Eagle's DRC?
You have to ask the PCB manufacturer you're going to use what their actual minimum hole size is. Eagle doesn't know that, its defaults lead to boards that are pretty agricultural by today's standards. smile
rp181
Mon Jan 24 2011, 11:13PM
15 mill came off advanced circuits website, along with the 6/6 traces. I found that odd since it is usually 13mill when it is 6/6.
rp181
Wed Jan 26 2011, 05:50AM
I have been working on this, and got them all routed with 15 mill vias except for 3 traces. I also was able to clean up lots of the traces and get rid of some vias, and managed to make the board quite a bit smaller as a product of the cleaning. I also think I got rid of the 6 mill traces (unless i missed some). there is still 6 mill spacing, but considering the chip leads themselves dont pass a 8mill DRC, I am fine with that.
If you can, could you take a look at the last three traces?
Thanks a bunch!
EDIT: nvm, it says 5 airwires, though I can only see 4. I bet I left a tiny one somewhere... I can fix the ground airwire connection to the center pad easily by moving the 2 pin header, I am mainly concerned about the 3 signal wires right now.
Wed Jan 26 2011, 09:35AM
To find those mysterious airwires, just turn off all the layers except "Dimension" and "Unrouted", they will be obvious.
Eagle's track placing algorithm is a little random, sometimes tracks don't quite connect to a pad and a minuscule airwire is left. Especially if you place imperial components on a metric grid or vice versa.
