  • Guests: 54
CCPS QUESTION..?
shady
Mon Jan 17 2011, 09:51PM Print
shady Registered Member #3597 Joined: Mon Jan 10 2011, 01:38PM
hey, i recently saw steve ward`s CCPS Link2 and i was wondering if i can build a transformer with 2 ferrite cores (each one consist of 2 u core face to face )
hocked together_ to inc. power capability_ with a cross section area of 615 mm2 and hight of 9 cm for every one of them . i will drive them with full bridge of irfp450 @ rectified mains in SLR topology at resonance freq. of about 100 KHZ.
my question is how many primary turns i need to avoid core saturation and also MOSFETS blow up cheesey
and what is the number of secondary turns for about 15 KV
and also what`s the max. output power i can expect ..?
REGARDS,
SHADY
Tue Jan 18 2011, 02:06PM
S,
At 100kHz, core saturation will not be an issue.
Cheers, Finn Hammer
shady
Tue Jan 18 2011, 02:54PM
i tried about 12 turn @ about 80: 145 KHZ with an old flyback
it worked well for 2 seconds and then my bridge blow up cry
Electroholic
Tue Jan 18 2011, 04:14PM
IGBTs are preferred for SLR inverters.
Scope shots?
You said flyback, is it half wave rectified?
shady
Tue Jan 18 2011, 04:18PM
yes..:-?
