  • Guests: 65
Oscillating relay
Zack
Mon Jan 17 2011, 05:42AM Print
Zack Registered Member #3624 Joined: Mon Jan 17 2011, 01:08AM
I wanted to make a little high voltage generator using an 8-pin relay and a wall transformer, but all I can do is get the relay to buzz. The transformer works fine for making single sparks. I think there is a configuration for this, does anyone know what it is?
Adam Munich
Mon Jan 17 2011, 06:15AM
The relay just becomes a buzzer because it's oscillating too fast. relays are quite slow, being mechanical devices and all. I recommend using a 555 timer to turn it on and off. Should get you a maximum of 40 sparks/sec. Link2
Electroholic
Mon Jan 17 2011, 08:16AM
Zack
Mon Jan 17 2011, 02:37PM
That's great! It works, and I'll post some pics soon.
edit: transformer burned out
