  • Guests: 33
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
Old tvs
1 2 3 4
Adam Munich
Mon Jan 17 2011, 01:21AM Print
So today I piked up an old philco TV. It looked pretty cool even though it was beat up pretty bad. Naturally I thought AC flyback.
1295225429 2893 FT0 Dsc09298
So just for S&Gs I decided to plug it in, and it took an unusually long time to show a picture. It eventually did, but the vertical sweep is broken.
1295225372 2893 FT0 Dsc09296
Tore the back off...
1295227291 2893 FT0 Dsc09312
Yeah I'd say it's old, certainly explains the warmup time. I thought about restoring it but I wouldn't even know where to begin. If I could find the issue I could fix that and make the plastic nice and new again. Although a knob is missing on the front.
So it's up to you 4HV, tear it up or is it worthy of an attempt to fix it?
Dr. ISOTOP
Mon Jan 17 2011, 01:33AM
I say it depends on how much space you have left for antiques in your house smile
Nah
Mon Jan 17 2011, 03:07AM
Nah Registered Member #3567 Joined: Mon Jan 03 2011, 10:49PM
Plastic?
If you want to waste money, than sure!
If you want a REAL tv, buy a good Scott 800b
Adam Munich
Mon Jan 17 2011, 03:34AM
Oh my god that thing is amazing. Must cost like $5000. If I get rich it's definitely going in my front room.
A peek inside the HV cabinet. If you follow the red wires you'll see the tube's heater is powered from a single turn on the core. Clever.
1295235157 2893 FT106392 Dsc09340
The tuner is pure genius. It's basically a different inductor for each channel, and they rotate to select a channel.
1295235134 2893 FT106392 Dsc09339
Made in america.
mccoywm72
Mon Jan 17 2011, 03:56AM
mccoywm72 Registered Member #2042 Joined: Sat Mar 21 2009, 03:44PM
I have to agree. I too have come across old tuners and they are quite clever in the configurations for channel select.
Coronafix
Mon Jan 17 2011, 05:00AM
Good score, a valve tv! Definately dimantle it and salvage the tubes
and transformers. That will be a rectifier tube after the flyback.
It wouldn't be much point fixing it, most stations are going digital now anyway.
radiotech
Mon Jan 17 2011, 05:26AM
The screen shot shows is mostly good. Get the schematic
and fix the vertical sweep. Ultra- not complicated.
If you fix it and it looks good there may be a market for it
in collectables. Its got to be clean. Check out the Philco group
in ARF, Television forum.
You might turn a good dollar on that thing or even trade
it for some good stuff. Thats a 60's vintage beast. The little box
you peeked into is called the doghouse.
Adam Munich
Mon Jan 17 2011, 05:35AM
I looked earlier and couldn't find a schematic. It's Philco R-1228-PGY if you want to take a look yourself.
I'm not sure if it's worth anything though. The case is kinda banged up and it's missing a knob...
pauleddy
Mon Jan 17 2011, 05:53AM
pauleddy Registered Member #2909 Joined: Wed Jun 09 2010, 12:31AM
i had a tv just like that, a philco, i pick it up from a trift store for 5 bucks
Mark-H
Mon Jan 17 2011, 09:37AM
Mark-H Registered Member #607 Joined: Tue Mar 27 2007, 10:39AM
"Turret" tuners were pretty much normal for the older VHF (50MHz) 405 line and dual standard TVs in the UK before everything went UHF in 84.
They can be the biggest source of annoyance with TV restoration as the faults on them are nearly always intermittent.
Some even had valves (tubes) mounted in them and they would shake loose or the HT contacts would come adrift.
Good luck with the restoration... :o) I've done a few... A labour of love for sure.
Cheers.
Mark.
