  • Guests: 55
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
Relativistic effects make lead acid batteries work?!
Sat Jan 15 2011, 06:34AM Print
interesting indeed...
wonder what they will find next, lithium iron phosphate cells use quantum effects?
-A
Dr. Shark
Thu Jan 20 2011, 03:46AM
If I remember the physics of atoms and quanta Link2 correctly - and it's been a while! - this is a pretty well-know effect that is used to calculate the emission spectra even for much lighter atoms then lead. The article makes it sound like a new discovery, but I think the basic principle is so fundamental that it's been known for a long time. It's fascinating tough, since it's definitely an area where quantum and relativist effects mix - something usually reserved for black holes!
Thu Jan 20 2011, 04:01AM
...something usually reserved for black holes!
Maybe speakers will turn out to be variable black holes according to this discovery, as old as it may be 0_o.
When i start thinking that deeply into things, i get creeped out and confused and i end up with my thoughts all foggy. That is why i prefer to not think too much about religion, and outer space! It is all just beyond my capability to understand.
plazmatron
Thu Jan 20 2011, 05:56PM
The unusual gold colour of the element Gold, is also down to relativistic effects.
The electrons travel around the nucleus of the Au atom so fast, that the increased electron mass causes certain electron shells to contract. This causes the gold atom to absorb light well into the blue end of the spectrum, rather than just at UV, giving it its characteristic gold colour.
Relativistic effects are also responsible for Mercury being liquid at room temperature.
Les
Sun Jan 23 2011, 09:14AM
hmm.
Wonder if this is why lead doping of the thallium superconductors makes the transition temperature increase?
Ages ago I read about some element which was allegedly discovered in ancient times that appeared pinkish-red.
Nowadays it is accepted that it was the oxide of mercury (aka cinnabar) or a gold/copper alloy.
I wonder if superheavy stable elements such as the theorised Element 122 would behave in the same way as gold?
Would also offer an insight into their magnetic and electrical properties.
-A
Bored Chemist
Sun Jan 23 2011, 10:38AM
Thallium's electrons are also relativistic.
Come to think of it, so are hydrogen's and everything in between. It's not as if "relativistic" suddenly switches on at some particular fraction of C.
