  • Guests: 39
seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
Constructing A Slingshot
Fri Jan 14 2011, 04:29AM Print
I'm preparing my equipment to do some long distance hiking, and I've planned from the start to take a slingshot along with me. My primary reason is for putting up my wire HF antenna for my radio. It will also give me a survival tool should I ever need to procure food in the woods, as well as a potential means of dissuading any particularly pushy black bears. A quick shot on the butt with a beanbag type round is usually enough to send them scurrying.
I watched This Video and that gave me a few ideas.
When it comes to hiking though, I'm what you call a 'gram weiny'. I go to extremes when it comes to reducing the weight I'm carrying. I think there's a lot I could do to both increase the functionality/accuracy/power of a slingshot while also reducing its weight and size quite a lot.
In that video, I saw The Vertical Slingshot and was intrigued. This might be one variety I'll try early on.
Anyone have any experience here, or some clever ideas on engineering the frame to be as strong, compact, and light as possible?
-Dave
Adam Munich
Fri Jan 28 2011, 05:57AM
I have made a couple slingshots before.
A couple tips:
*Angles > 40* are pretty weak.
*Use hardwoods if you are planning on using wood.
*If you need to join pieces of wood roughen it up and use glue, then put in some screws before the glue is dry.
*If you need to make an inline splice use a peg and some glue.
*Surgical/rubber tubing is best. You can get it at home depot in the plumbing section.
*Make the "grip part" (dunno the terminology) out of leather. Leather is definitely best, thick stuff.
That's all I can think of rite now. Goodnight.
rp181
Fri Jan 28 2011, 06:32AM
Jorge is indeed great at those. He is on spudfiles.com, and I bet he would help you out.
Heres his thread: Link2,start,885.html
He really cranks them out.
Fri Jan 28 2011, 09:44AM
Martin King Registered Member #3040 Joined: Tue Jul 27 2010, 03:15PM
There's a nice little Titanium one here Link2 supplier Link2 Otherwise I like the idea of using carbon fibre.
Martin.
Adam Munich
Fri Jan 28 2011, 02:39PM
That is a nice slingshot. Sadly it's kind of expensive.
Ash Small
Fri Jan 28 2011, 03:59PM
Martin King wrote ...
Martin.
I wouldn't recommend using carbon fibre for the reasons I was didcussing with Dave in the chatroom the other night.
Carbon only has strength in compression. Unless you know exactly what you are doing it's quite possible that you'll end up being hit in the face by flying carbon shrapnel. Not something you'd want to happen miles away from the nearest casualty unit.
I'd recommend something like 1/8" by 3/4" stainless (316 is a lot stronger than 304, and is the same weight) as a starting point. easy to work, strong and tough.
Fri Jan 28 2011, 06:55PM
But half the fun is in learning how to make one that won't snap and then building a test rig to flex it several thousand times to check that you're right. A Kevlar/Carbon hybrid might be a better bet Link2 . Also (after making several throwing knives and other items) I wouldn't say that stainless is THAT easy to work with as it work hardens when cutting so you need the right tools/technique.
Martin.
teravolt
Sat Jan 29 2011, 02:58AM
Hi Dave, I am not sure whether you want to build a sling shot or self protection. If you still want to use been bags on bears you may end up just pissing them off. However I found a decent wrist rocket at
among others.
If I were you I would just avoid the rangers as much the bears if you have one of these devices. I prefer a wrist rocket over ordinary slings because it offers better control.
Ash Small
Sat Jan 29 2011, 03:52AM
Martin.
Stainless is A LOT easier to work than titanium and it's alloys. While I usually use an angle grinder to cut stainless, a sharp hacksaw will do the job, especially if you apply a bit of cutting compound/spray. It's also easy to weld with a low powered stick welder, although welding may not be required for this project.
Sat Jan 29 2011, 02:37PM
Ash Small wrote ...
Er. yes but it's still not "easy to work". I wouldn't like to try and cut 1/4" stainless with a hacksaw and even 1/8" would be pushing it. You also have to be careful if using an angle grinder not to let the work get too hot. There's some useful info on machining Stainless here Link2 . You also have to be careful if cutting with an angle grinder (Particularly with thinner material such as 1/8" ) as you risk overheating the stainless and softening it.
Martin.
