  • Guests: 32
seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
This scares me abit
ubuntupokemoninc
Fri Jan 14 2011, 02:32AM Print
ubuntupokemoninc Banned on 1/22/2011 for repeated rule violations after multiple warnings.
Registered Member #3299 Joined: Sat Oct 09 2010, 08:11PM
go to the very most bottom of the page, and you will see what i mean.
I need to make sure i don't accidentally do this!
Coronafix
Fri Jan 14 2011, 07:56AM
Just make sure your design allows for flexibility, his didn't.
He had the base of the tube bolted to the plexy, then the buss bars screwed to the plexy also. When he tightened the clamp, it had no play and cracked the tube.
Good luck!
ubuntupokemoninc
Fri Jan 14 2011, 10:16PM
this is my plan. what do you think?
pretty good for ms paint wink
2
Robert2
Sat Jan 15 2011, 07:41AM
Robert2 Registered Member #1773 Joined: Tue Oct 21 2008, 06:56PM
Its my idea
2
Sat Jan 15 2011, 07:57AM
ouch, that sucks for the poor guy, those tubes are expensive!!
-A
Coronafix
Sat Jan 15 2011, 08:25AM
I don't think alligator clips are going to cut it.
ubuntupokemoninc
Sat Jan 15 2011, 03:04PM
I could use something like they use a car battery connector only a little smaller?
thanks for doctoring my design wink
Sat Jan 15 2011, 04:22PM
ubuntupokemoninc wrote ...
You can jump start a car with such clips since its for a very short period and when charging a battery you are nowhere near the starter engine load.
That tube draws 20 -27A continues and will need some proper connections, just make them flexible with copper strap, flex or several thinner wires in parallel connected between the clamp on the legs and source :)
Sat Jan 15 2011, 07:07PM
Martin King Registered Member #3040 Joined: Tue Jul 27 2010, 03:15PM
Coronafix wrote ...
Agreed, look at the design of a lot of sockets (and plugs) and note the fact that they allow they often allow the pins to "float" to allow for self alignment. Where he mounted the Ali bars to the Plexiglass he should have drilled the holes for the mounting screws oversize and then not done the screws up tightly (and probably put washers between the screws and the Plexiglass). Mind you, you also need to check whether the Plexiglass can take the heat that it will be exposed to. A thick Paxolin sheet may be better? But I don't know much about these tubes.
Martin.
ubuntupokemoninc
Sun Jan 16 2011, 04:48AM
what if i blew the air threw it instead of sucking?
