  • Guests: 73
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
Cabinet and Enclosure Sources
Thu Jan 13 2011, 07:52PM Print
I'm hunting for a specific sized enclosure for an upcoming project, and so far the usual surplus suppliers haven't yielded any luck. I've checked Alltronics, All-Electronics, Hosfelt, and MPJA (they have a few 'maybe' enclosures, but they're spendy).
I'm looking for something either very light weight aluminum, or plastic. It needs to be a design capable of being waterproofed, and roughly 5.5"x5.5"x3".
Anybody have a favorite source for this sort of thing?
-Dave
Thu Jan 13 2011, 08:25PM
Could you use plywood?
You could treat it with any number of preservatives and/or coatings,
or cover it in a 'skin' of aluminium or plastic.
A 'flight case' as used by bands etc. ?
A water tank ?
what are the requirements?
- weight
- strength
- durability
- cosmetics etc...
Thu Jan 13 2011, 09:00PM
In my case, plywood would be much too heavy.
This will be to house my $600 radio (FT-817 removed from its housing and frame) during a 4 month cross country hike.
My dimensions there are wrong, they should be in inches, not feet, sorry. Light weight and waterproof are the two requirements beyond size.
-Dave
Ash Small
Thu Jan 13 2011, 09:37PM
Thin plywood, covered in fibreglass?
Fri Jan 14 2011, 01:54PM
D'oh .... I read feet instead of inches
I sometimes make enclosures by soldering together pieces of double-sidded copper-clad pcb material...very strong, electrically conductive/emi screen, easy to cut/drill etc.
When constructed clean and buff, add any artwork then spray with a coat of pcb laquer to prevent tarnishing
P.S. you can also use the inside walls for heatsinking or mounting circuits 'ugly' or 'Manhattan' style.
cavemen
Fri Jan 14 2011, 05:21PM
cavemen Registered Member #2008 Joined: Tue Mar 03 2009, 05:11AM
You live in United States, so do I.
Go to Lowes and ask for scraps of plexiglass.
Then cut that with a tablesaw or score with a kitchen knife and break.
Score many times over the straight edge and break on the edge of the table, while pressing down with a board to keep the breaking line from bulging up.
I have a whole tecnique for this kind of cheap production I can tell about.
Adam Munich
Fri Jan 14 2011, 09:25PM
Have you checked craft stores? They usually have some nice small wooden boxes. It's pretty easy to waterproof them too, some polyurethane and a rubber band gasket works just fine.
Fri Jan 14 2011, 10:02PM
Wood is definitely not going to work in this case. Too heavy, to easy to damage, impossible to genuinely waterproof.
Plexiglass would be too heavy and too easy to break. This will be for my portable ham radio during my upcoming hike.
If I have to fabricate the box, it will be done by creating a mold and using high pressure injection molding (I have access to tool & die shop) and some kind of highly impact resistant plastic like ABS.
I'd much rather go with a purchased enclosure though, much cheaper, easier, and faster.
Anybody got a favorite surplus place that specializes in enclosures?
-Dave
Sat Jan 15 2011, 12:29AM
Dave,
Thats simple. If it just needs to be waterproofed, just get a small waterproof utility bag like the kind they store equipment in during scuba diving or other outdoor sports.
Lightweight, cheap, and 100% waterproof.
Maybe even a underwater point-and-shoot camera bag. They small and cheap.
Carbon_Rod
Sat Jan 15 2011, 04:41AM
The cheapest and fastest way to build just about any type of box you need out of 1/4'' poly
Duct-tape and plywood rigs are fine for this type of construction.
wink
