  • Guests: 28
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
Acetone on circuit board
Michalis.Biochem
Thu Jan 13 2011, 07:50PM Print
Michalis.Biochem Registered Member #3340 Joined: Wed Oct 20 2010, 07:28PM
Ok, so i have this circuit board which has a laser diode soldered on it. The laser diode itself has a heatsink on which is glued. As far as i know acetone can dissolve almost any glue. So the question is, can i put some acetone on the glue to dissolve it or is this going to damage the laser diode?
Thu Jan 13 2011, 07:54PM
This might work, the only risk is that the acetone might dissolve the glue holding the diode window in place.
-A
Thu Jan 13 2011, 08:06PM
Can you protect the diode with something, like heat shrink tubing while you use the acetone? Then, cut it off when done.
Michalis.Biochem
Thu Jan 13 2011, 08:17PM
Conundrum wrote ...
That's what i thought.
Thank you!
dmg
Thu Jan 13 2011, 10:14PM
Can you post a picture of it?
If this is an exposed die style of diode (open can or chip), acetone will destroy either the facet or potentially the die itself.
