  • Guests: 47
09/19 raff (48)
09/20 PYLEMET-mk2 (36)
09/21 Bill G (65)
Air gap flash
Adam Munich
Tue Jan 11 2011, 06:46PM Print
I found this on hackaday, an air gap flash for high speed photgraphy. Honestly it's the coolest thing I've ever seen someone do with a capacitor. So, those lucky enough to have one of these HV caps on hand, I'd like to see you do this.
Bullet VS Brass rod
1294771547 2893 FT0 Shot Squash1
Tesladownunder
Sun Jan 16 2011, 07:56AM
I am probably speaking about things I don't understand, but I would bet that air vs Xenon is no different in spark rise time from the point of view of this practical application.
The real difference is in the discharge of the pulse cap.
In a camera flash, this is a simple electrolytic, notorious for a slow discharge rate. (eg it is very hard to do can crushing with electrolytics)
in a Q switched laser pumped with a Xenon flashlamp like in the common rangefinder lasers there is a (polypropylene) capacitor 32 uF 600V with a 0.03 mH inductor as a pulse-forming network.
If you use a pulse cap for higher voltage (10kV +) that you need for an air gap , you are probably going to get a higher discharge rate than a lower voltage (600V for a Xenon).
Hence for these reasons, it appears that an air gap is faster.
He is going to reduce his caps lifetime by the direct shorting of the output, including his shorting stick.
Sun Jan 16 2011, 10:12AM
The secret is that atmospheric air has a higher breakdown voltage than an ordinary flash tube, so it matches a high-voltage, low-capacitance capacitor, delivering the same energy in a shorter pulse.
If you wanted to run a xenon flash tube off 10kV, it would need to be very long to avoid self-triggering, or you could use a triggered air gap to switch it. But then you might as well just use the air gap as the flash, which is where we came in.
I think several 4hv members have done this in the past, try looking through the archives.
Thomas Rapp made a high-speed flash that does use a xenon tube fired by a triggered spark gap. Link2
Wolfram
Sun Jan 16 2011, 11:30AM
Tesladownunder wrote ...
There is not much difference in the rise-time as far as I know, but xenon has significant afterglow in flash tubes.
Edgerton found that the shortest flashes could be developed by discharging the capacitors in air. Gases such as krypton and xenon, which are found in conventional discharge lamps, continue to glow strongly for a substantial period of time after the electric current has ceased.
Dr. ISOTOP
Mon Jan 17 2011, 01:06AM
Hey, I think I found a use for my spare 50KV 75nF pulse capacitor! smile
Adam Munich
Mon Jan 17 2011, 05:55AM
Would doorknob caps be fast enough?
Adam Munich
Tue Jan 18 2011, 04:38AM
Hello? You know, those ceramic doorknob caps.
Turkey9
Tue Jan 18 2011, 09:40AM
Since ceramic caps have very low ESR similar to film pulse caps I'd imagine they would work... the only danger would be dielectric degradation from fast discharges. Check the data sheet or contact the manufacturer to see. Other wise you'd just need a big enough cap to get a usable pulse length.
P.S. Be patient and wait longer before double posting something meaningless. We're trying to up the quality of the posts, aren't we?
Dr. Shark
Thu Jan 20 2011, 03:39AM
The main problem with the doorknobs it that the most common ones only store a few J of energy each, which would make for a very dim flash. Even disposable cameras have an order of magnitude more oomph in the flash circuit. For macro work where you don't need to light up a whole room I see no problem though, the discharge would certainly be fast enough seeing how these caps are used for nanosecond pulses in longitudinally excited nitrogen lasers.
Adam Munich
Thu Jan 20 2011, 05:39AM
Hmm, maybe I could make my own caps...
