  • Guests: 21
seveerz (69)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
GU-50 tube datasheet.
Mon Jan 10 2011, 11:18PM Print
Today i received my 4 GU-50 tubes. As always, i checked the datasheet for the pinout. I cannot understand it, though!
Alright, so it says pin 2 is grid1, pin 3 is grid2, and pin 5 is grid3. But then, pin 7 is titled 'screen'. I looked in the tube at where pin 7 went, and it is connected to a metal plate that is under the plate and grids and cathode, which i cannot tell if it is connected to a grid. Which pin is what? confused
It is weird having a tube with a metal piece on the top that is not the anode, that really threw me off tongue
Tue Jan 11 2011, 12:15AM
You are confusing the screen grid - g2 on pin 3 - with the internal screen tied to pin 7.
So you have
pin 1 - cathode
pin 2 - control grid
pin 3 - screen grid
pin 4 - heater
pin 5 - suppressor grid
pin 6 - anode
pin 7 - internal screen or shielding
pin 8 - heater.
The role of the internal screening shield is to prevent interaction between the leads to the various valve elements which would otherwise represent a path that could not be wholly controlled by changes in the control grid voltage.
In the absence of other information, I would connect the internal shield on pin 7 directly to Earth, and the suppressor grid on pin 5 directly to the cathode on pin 1.
Tue Jan 11 2011, 02:25AM
Thanks Proud Mary, you're great cheesey
