  • Guests: 38
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
Staco 2510 (Variac) Refurb?
sngecko
Mon Jan 10 2011, 10:26PM Print
sngecko Registered Member #3447 Joined: Fri Nov 26 2010, 11:10PM
I just acquired a used Staco 2510. It came without a knob or dial, which I purchased new (ouch!) for ~$75 each...
I have a couple of questions before I put it into service:
(1) The brush looks pretty worn to me; it's almost to the non-carbon metal on one side. See picture. Should I spring another ~$71 for a new one?!
(2) The brush assembly does not press against the winding, as I would imagine it should. If I were to attach the knob tightly it would hold it properly, or if I put in a small leaf spring of some sort, it would apply a constant binding pressure. Are these things supposed to have a mechanical means of applying pressure between the brush and the winding?
(3) I'm not sure what the grey plastic bit on the back is supposed to do, but it has a couple of hairline cracks in it. See photo. Is there something I should know about this little grey bit?
Thanks,
sngecko
1294698390 3447 FT0 2510
1294698390 3447 FT0 2510rear
1294698390 3447 FT0 2510 Brush
Adam Munich
Tue Jan 11 2011, 12:44AM
You paid $75 for a plastic knob??
But the brush is broken on this thing, the brass is supposed to hold a carbon brush. You can get them here but they are pricy. Link2
The plastic just looks like some kind of retainer. If it breaks a little super glue will fix it.
sngecko
Tue Jan 11 2011, 01:36AM
Update: After removing the contactor plate, I discovered that (1) the carbon brush had been pulverized between two windings and (2) probably the same pressure that caused 1, above, destroyed the plastic/ceramic axel that the rotor turns on. The rotor was only held on by the three-point set screws on the aluminum shaft. It pulled right off.
Mystery solved: It's a case of either poor packaging or UPS gorillas.
Yeah, those knobs are insanely expensive. The dial was $85! I'm going to try to return them to AlliedElec. Oops.
radiotech
Tue Jan 11 2011, 07:01AM
What is the voltage and frequency rating of that Variac.
It kinda looks like a 400 Hz one.
sngecko
Wed Jan 12 2011, 12:24AM
It's a 50/60Hz model, 25A continuous current, 120/140 V unit. A really great model for linear power supplies.
Adam Munich
Thu Feb 03 2011, 02:56AM
Please check your PMs sngecko.
