  • Guests: 61
2 stage Coilgun HALO STYLE
Zero
Sat Jan 08 2011, 02:34PM Print
Zero Registered Member #3588 Joined: Sat Jan 08 2011, 11:19AM
Ahoihoi
3 kg of solid metal and 100 hours of work
BTW: Is there a way to embed the link? With picture and everything....
Muttyfutty!
Sun Jan 09 2011, 08:34AM
Muttyfutty! Registered Member #2915 Joined: Fri Jun 11 2010, 10:41AM
I'm getting a 404 error with your link...
Zero
Sun Jan 09 2011, 09:50AM
Funny....me too.
Works with copy and paste though.
Admins...help!? oO
Adam Munich
Sun Jan 09 2011, 03:05PM
How did you make the case?
Zero
Sun Jan 09 2011, 05:48PM
Brass sheet and a pair of scissors....a bit of solder here and there...
Turkey9
Sun Jan 09 2011, 07:11PM
Very nice craftsmanship as far as I can tell, well done!!! Do you have some numbers for us?
Zero
Sun Jan 09 2011, 07:22PM
- Weight: 2 kg
- Dimenssions: 280x150mm (ca)
- Body is made of 5mm aluminum
- Housing 0.5mm brass
- Paintjob chromepaint and orange clearcoat
- 2 stages 100+50J
- Projectiles: Steel 5.6mm 15mm long round tip
- Energy source 4x 3.7V Li Ion 14500
- Second coil switched on by contacts
- Aiming laser 30mW DPSS green
- 80 hours of work
Saz43
Wed Jan 12 2011, 05:04AM
Excellent work! It's good to see another coilgunner who is concerned with the appearance of the final product.
Zero
Wed Jan 12 2011, 03:25PM
Actually its even better: Functionality and look in perfect relation...
Wont like to have a BIG but good looking rifle which isnt able to pierce piece of paper.
Do you have some coilgun-vids uploaded?
Saz43
Thu Jan 13 2011, 08:19PM
Zero wrote ...
Yep but youve seen it (I'm Larsplatoon). I have a second coilgun in the oven, see the thread called "help me design a half-bridge coilgun". But its not even in the test phase yet so no hype.
