  • Guests: 47
Requesting a Troubleshoot -- ZVS Flyback Driver-- SOLVED
Ruben
Fri Jan 07 2011, 02:12AM Print
Ruben Registered Member #3263 Joined: Sat Oct 02 2010, 04:43AM
Hey all,
I attempted to knock up a Mazilli type flyback driver last night:
--First attempt with IRF250's which I forgot to isolate from the heatsink. After adding insulation i was able to pull an arc for maybe 1 second (5.5 A @ 20 v from a SMPS) , after which there was no output. All parts were stone cold at this point.
-- Thinking I may have killed my FET's with too small an inductor (~25 turns on an unknown core) I rewound the inductor with ~ 45 turns of MOT primary wire (~1.2 mm), and replaced the FET's with IRF460's I had on hand.
At this point I get nothing-- No output, no high pitched whine, and a measured 5 mA current draw @20 v input.
My capacitor is 3x2 1uf MKP X2's to give 0.66 uf, I believe the core I am using is iron powder (significantly more magnetic than ferrite, and salvaged from a 12-24v DC-DC converter)
1294365428 3263 FT0 Images001 1294365428 3263 FT0 Images002
1294365428 3263 FT0 Images003 1294365428 3263 FT0 Images004
Any suggestions as to where I should look for the problem would be greatly appreciated. I'm hoping its something stupid and inane that I've clearly done wrong.
Cheers
**Edit -- Thread Title
Ash Small
Fri Jan 07 2011, 02:19AM
My interpretation is that you need ferrite rather than iron powder cored inductor.
This probably doesn't address your question in full.
(I'm still working out how the Mazilli ZVS circuit works, but iron powder only works for low frequencies. Some-one please correct me if I'm mistaken.)
steven968
Fri Jan 07 2011, 03:45AM
steven968 Registered Member #3516 Joined: Wed Dec 15 2010, 10:40AM
I reckon ferrite core is applicable cause it works under high freq.
try to use G80N60 (IGBT), u will get better arcs.
Wolfram
Fri Jan 07 2011, 05:51PM
steven968 wrote ...
But an ungapped (as toroids usually are) ferrite core will saturate if there is a DC component in the inductor current, and most of the inductance disappears. Some people has claimed that it works for them, but in these cases it would work exactly the same with a much much smaller iron powder-cored inductor.
Kolas
Fri Jan 07 2011, 06:13PM
Kolas Registered Member #102 Joined: Thu Feb 09 2006, 08:15PM
are you supposed to be using wire wound resistors?
that added inductance there might cause it not to oscillate.
tritium
Sat Jan 08 2011, 10:17AM
tritium Registered Member #2591 Joined: Fri Jan 01 2010, 11:58AM
you hav to use fast diode's, what type do you use now?
Ruben
Mon Jan 10 2011, 12:47AM
Thanks for the suggestions guys.
I'm planning to rebuild with new components, and 2W carbon film resistors on a veroboard (inductor and FETs off-board)
The diodes Im using are UF4007's. Im waiting for some IRF260s in the mail, but I'd at least like to get SOMETHING using the 460s
**Edit --SOLVED**
So it turns one of the alligator leads I was using was open circuit!!! GARR If you want to waste 3 hours of your life, do as i do, and be sure to check such things LAST.
I did rebuild the driver on strip board (minus inductor, capacitor, and FET's), and I've spent the evening pulling fiery 5.5 inch arcs @32v. My smallest flyback got hot fast, and has already died open circuit.
Any ideas on what to do with a smallish ferrite core?
