  • Guests: 45
seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
Schottky Diodes in //
Adam Munich
Sat Jan 01 2011, 05:04PM Print
I have a question. I need a fast power diode for my buck converter and I found a double schottky rectifying diode in that big PSU I took apart. Link2
Can I tie to diodes together for more amperage? (Does a schottky diode have a positive temperature coefficient)
Ash Small
Sat Jan 01 2011, 05:32PM
I tried this recently, but not with shottkys. They seem to be sharing the current ok.
Try it and see, limit the current to what one will take and see if they both warm up the same.
I found they didn't all switch on together, but as the current increased, they shared the load more evenly.
Sat Jan 01 2011, 10:28PM
I have paralleled two 20A/1200v schottky's for my buck converter. I have taken it to over 12kw of output power. I suggest water cooling them.
Sun Jan 02 2011, 11:49AM
Were those SiC schottkys? Can you tell us the maker, part number and maybe even the price? smile
Adam Munich
Sun Jan 02 2011, 03:21PM
I got them out of that big PSU I took apart. See here: Link2
Good luck buying one.
Nvmd I found it: Link2
You're better of just buying a psu. Link2
There's 2 in there, Plus 2x irfp 460s 2x irfp250's, some thick litz wire, and some more schottkys.
Sun Jan 02 2011, 03:58PM
No, not you, Iamsmooth with his 1200V schottkys.
Sun Jan 02 2011, 06:32PM
This is exactly what I used. I used two in parallel.
Digikey sells them
At the power levels I am using I am using my trialed and successful watercooling system. I presume most here who work with this amperage are familiar with how to set something up, but if there are those who want to know I can take some pictures of my cooling setup. It is the same one I've used for cooling my mosfets and igbts.
Adam Munich
Sun Jan 02 2011, 06:37PM
That's 74 dollars worth of diode! O_o
Sun Jan 02 2011, 09:43PM
A commercial induction heater capapble of 10kw is easily over $10k.
A smps or scr power control is usually near $1500.
Adam Munich
Sun Jan 02 2011, 10:34PM
So my 48V 6A SMPS makes me a rich man? tongue
Yeah, I don't see any reason for a diode like that to be so expensive.
