  • Guests: 32
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
Electrically heated synthetic diamond scalpels
Carbon_Rod
Sat Jan 01 2011, 05:32AM Print
I am looking for a commercial source of cauterizing synthetic diamond double-lancets
There was a publication suggesting these are available:
But I have only found a single supplier of regular blades:
This intended use was for industrial purposes, and does not need to be medical grade.
Does anyone know of a sub-$200 source?
Specifically, I am seeking a description of the wear life compared to heated stainless steel.
IntraWinding
Sat Jan 01 2011, 02:37PM
I did a Google for you, but the item you link to seems to be an idea rather than a product. Diamond is a superb thermal conductor (much better than copper) so it should be very easy to heat any diamond blade held in a metal clamp/handle by simply heating the clamp/handle. Can't help beyond that. I've always wanted a diamond scalpel, but I wonder if in practice it's edge is very brittle making it only suitable for soft materials, like ceramic knives.
Bjørn
Sat Jan 01 2011, 07:21PM
Diamond blades can cut metals and ceramics but the force and angle must be perfectly controlled. I doubt many people on earth can do it by hand.
The lifetime would probably range from forever to a second depending on what is being cut and how.
IntraWinding
Sat Jan 01 2011, 07:43PM
Bjørn wrote ...
And how hot is 'Hot'?
Carbon_Rod
Tue Jan 04 2011, 05:16AM
FYI:
Based on the tooling wear life,
I looked into a lower cost plasma sharpened Diamaze product.
PSD Manufacturer:
Youtube clip:
Cheers,
IntraWinding
Tue Jan 04 2011, 09:50AM
Wow! Those are very interesting!
Any guesses how Plasma Sharpening works?
Nice pics Link2
