  • Guests: 32
seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
Inside a 5403 Tektronix scope (lots of pics)
dmg
Mon Dec 27 2010, 04:28AM Print
I was a bit curious to see the insides of my scope, peeking through the vents I saw a whole bunch of old and outdated parts just waiting to say Hi.
I thought Ill share with you guys some pictures of what it looks like.
First off, the scope assembled:
Themachine
There are a screw tabs that need to be turned counter-clockwise 90 degrees to loosen the cover.
Sidebolt
Popped the cover off
Coveroff
Close up
Scope004
Scope006
second side uncovered
Scope007
HV supply cover - Ill deal with it later
Scope008
Scope009
CRT leads - probably X-Y
Scope010
A close up on the board:
1972... Older then myself thats for sure... the dust and date do not lie.
Scope012
more assorted boards
Scope013
I removed the cover of the HV supply, there is a black box with an HV lead (most likely cathode)
Scope015
Scope016
Scope017
This scope had 3 modules, but I only use 2 of them (dont really need the third one.)
first module is the scope's settings, seconds/div, etc.
the other is for 2 channels.
Scope018
Scope019
Scope021
Sockets for modules:
Scope023
I noticed an odd looking coil in there.. I have no idea what it is for, anyone know?
Scope025
closeup of coil
Scope024
another close look of the tube's what is most likly either the X/Y leads.
they are little ceramic plugs that fit inside the tube.
Scope028
other side of a powersupply
Scope029
Back of the socket board for the modules
Scope030
The IC's do not have any part numbers of identification.
Scope031
Bottom cover
Scope032
Removed, you see the underside of a power supply and the railing for the modules.
Scope033
Scope035
more capacitors
Scope036
Scope037
And last but not least, the scope running without the covers cheesey
Scope038
Id like to know if anyone has any idea what that big coil of wire is used for.
Mon Dec 27 2010, 04:37AM
I bet the "coil" is a coaxial cable transmission line, used to delay the vertical deflection signal. Lets you see the waveform a few nanoseconds before the horizontal sweep trigger event.
dmg
Mon Dec 27 2010, 04:39AM
yes, it is coaxial cable, I guess thats the only reason for it to be used anyway.
Thank you.
Ash Small
Mon Dec 27 2010, 04:59AM
Manual (including circuit diagrams) is here:
dmg
Mon Dec 27 2010, 07:04AM
Thanks for the manual Ash, I was looking for that for a while.
radiotech
Mon Dec 27 2010, 11:20PM
And what about the shroud around the CRT? what's it made of and
why is it there?
dmg
Mon Dec 27 2010, 11:57PM
The shroud's made out of tin sheeting. it does not serve as a critical part for function, but its there to protect the CRT from damage (my guess is from tools or accidents when the techs where building the scope). It can also protect the scope from the CRT itself. In an event of rupture, and if the tube actually managed to shatter itself to many pieces, the boards and parts would be spared of the flying glass.
mikeselectricstuff
Tue Dec 28 2010, 12:09AM
The shield is probably made of mu-metal. This provides magnetic shielding to prevent magnetic fields affecting the CRT electron beam.
Tue Dec 28 2010, 03:58AM
mikeselectricstuff wrote ...
I second this opinion.
dmg
Tue Dec 28 2010, 04:01AM
Ill third it.
makes more sence then what ive said..
