  • Guests: 41
seveerz (69)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
Tantal cap
Sun Dec 26 2010, 09:56PM Print
How is polarised this tantal cap?
Th
Sun Dec 26 2010, 10:06PM
first, put a volt meter across that cap, to see if there's any residual on it.
Kilham
Sun Dec 26 2010, 11:17PM
Kilham Registered Member #2814 Joined: Wed Apr 21 2010, 12:28PM
My guess would be the side with the blob is + and the case -, if you have a few of them spare and can risk possibly damaging one try applying a low voltage and measuring the leakage current both ways.
Mon Dec 27 2010, 11:08AM
yeah, i use this approach.
best to limit reverse voltage to 0.6V using a pair of antiparallel diodes across the capacitor though.
-A
Mon Dec 27 2010, 02:37PM
Thanx guys.
Tue Dec 28 2010, 03:51AM
Kilham wrote ...
Conundrum wrote ...
-A
I was going to suggest measuring leakage current second, as it may degrade the specs a bit. so if it has a residual charge, that polarity will be the true polarity, so try that first, if not then check reverse leakage second.
