  • Guests: 30
seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
Header cable
cduma
Sun Dec 26 2010, 03:51AM Print
Im trying to connect my arduino via the headers to a PCB with a 3D matrix of LEDs and I cant seem to find an appropriate cable. Can anybody offer any insight?
Adam Munich
Sun Dec 26 2010, 04:09AM
cduma
Sun Dec 26 2010, 04:39AM
Sorry, nice try though! Not even close to what I am looking for.
Adam Munich
Sun Dec 26 2010, 06:05AM
what kind of cable then? There are so many types of connectors in electronics...
cduma
Sun Dec 26 2010, 08:58AM
I need a 1X20 male header to ribbon(cable or whatever) to some sort of solderable connector. 2 1X10 or similar would also do well for me.
Sun Dec 26 2010, 09:10AM
take a 40 pin IDE harddisk cable and and strip it down to what you need, I used that for a LED cube.
Electroholic
Sun Dec 26 2010, 11:02AM
Doubt you will find cable assemblies terminated with header pins. 99% of the time, you put the pins on the board for a board to cable connection. Female headers are more for board stacking like the different arduino shields that you see, having female headers on the board also makes it easy for prototyping with 24awg jumpers and breadboard.
Your best bet is to make one your self out of some header strip and old IDE ribbons.
Protips:
If you plug the pin header in a female socket when you solder, even if you melt the plastic, the pins stay aligned.
Also, if you solder the pin header on a small strip of protoboard laying down, like this Link2 , it will give the finished connector more structural support.
cduma
Sun Dec 26 2010, 04:31PM
I suppose I will just use an IDE cable.
