  • Guests: 43
seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
What is test inputs on tl494
ubuntupokemoninc
Sat Dec 25 2010, 10:35PM Print
ubuntupokemoninc Banned on 1/22/2011 for repeated rule violations after multiple warnings.
Registered Member #3299 Joined: Sat Oct 09 2010, 08:11PM
I'm designing a circuit, Link2 is the base of the circuit and it says test Input, is that pulse width modulation? I don't need pulse width modulation, so do i just not put anything there?
cjk2
Sat Dec 25 2010, 10:49PM
Ground the Dead time control (I think) and apply a variable voltage to the feedback pin to vary output duty cycle.
ubuntupokemoninc
Sat Dec 25 2010, 11:31PM
how much do I vary it? the values i'm putting in to the circuit will make the chip run at 110khz, then it will be interrupted with a 555 chip.
Adam Munich
Sun Dec 26 2010, 01:30AM
"make the chip run at 110khz, then it will be interrupted with a 555 chip"
Is this for a plasma speaker, or an audio modulated tesla coil? The sg3525 does an excellent job at audio modulation.
ubuntupokemoninc
Sun Dec 26 2010, 02:24AM
Its for a drsstc wink
Adam Munich
Sun Dec 26 2010, 02:27AM
I'd just use the SG3525 then. It's easy to make a half bridge with it, and it runs fine at 110khz.
ubuntupokemoninc
Sun Dec 26 2010, 03:10AM
Man i already have the circuit made, and i have all the parts for the tl494 lying around
