  • Guests: 32
seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
cupboard door activated mains LED regulator
Avi
Thu Dec 23 2010, 05:19PM Print
What are some methods to switch 240v mains to a ~350ma constant current regulator activated by opening a cupboard door?
The method should be both safe and comply with electrical wiring safety regulations.
Running mains (even current limited) to a reed switch to drive a triac is probably not considered safe. Is anyone aware of any other approaches preferably not involving separate batteries, which need to be replaced, or leak, over time.
Wolfram
Thu Dec 23 2010, 05:44PM
What about a small mains transformer to power a circuit where the door switch turns on the LED in a triac-output optocoupler?
Avi
Thu Dec 23 2010, 05:50PM
I'm not sure if that is any more/less efficient then leaving the mains side of the regulator always on, now that i think about it, i don't even know if its safe to switch its low voltage side, its some switch mode design, i don't have the schematic.
But yes, that is a usable idea, so thanks so far.
Coronafix
Thu Dec 23 2010, 07:49PM
There must be a mains rated momentary switch out there. Lights in pantries is pretty standard now, someone like Arlec must have something to do the job.
Dr. Slack
Thu Dec 23 2010, 08:23PM
Have you ever pulled a microwave oven apart to to the transformer, capacitor, magnetron etc? There are at least two, sometimes half a dozen mains-rated microswitches in there as well for things like door interlock. I've got one on my garage door, mounted inside a tiny plastic project box, which makes it double insulated. It's actuated by a cam made from a couple of bits of Lego (tm) Technik fastened together with polystyrene modelling glue.
radiotech
Thu Dec 23 2010, 08:32PM
A 1/3 amp constant current regulator is just asking
for trouble. What voltage imits have you placed on this device?
Avi
Fri Dec 24 2010, 04:25PM
as for running mains wires up to a door switch, which is different than a 100% boxed sealed product, does anyone know if there are any regulations against this?
radiotech wrote ...
for trouble.
What, why? the board was designed to do this, or so it claims.
Adam Munich
Fri Dec 24 2010, 04:44PM
That is all.
Avi
Sat Dec 25 2010, 04:55AM
Grenadier, this thread is not about the switching 'circuit', its about that these circuits need power (even if it a low voltage) to be able to apply a voltage or current to them to trigger it.
conclusions so far:
A separate constantly running transformer that outputs a low voltage
running mains cord directly to the door switch and no opinions yet of if that meets/doesn't meet regulations?
Adam Munich
Sat Dec 25 2010, 04:58AM
Normally closed microswitch? There's nothing wrong with switching the mains.
