  • Guests: 26
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
TL949 calculations arn't working out right
ubuntupokemoninc
Tue Dec 21 2010, 11:34PM Print
ubuntupokemoninc Banned on 1/22/2011 for repeated rule violations after multiple warnings.
Registered Member #3299 Joined: Sat Oct 09 2010, 08:11PM
I'm am trying to calculate the resistance of Rt to get 110khz, but before i tried this i was gonna work the given example on the data sheet, It was gonna find the resistance of Rt to get 20khz if Ct = .001uf
here is the equation Rt= 1.1/fxCt
Rt=1/[(20x10^3)x(.001x10^-6)=50k ohms, but the answer i get is... 0 angry
Then i go to a different calculator and i get 3.94796328 × 10-18 blah blah blah blah blah!
I need some help mistrust
Pinky's Brain
Wed Dec 22 2010, 01:02AM
Assuming that you left off a bracket by mistake (there is supposed to be an additional one in front of the =) I imagine you are screwing up the operator precedence (not going to explain that here, just look it up). With windows calculator in scientific mode I'd enter it like this :
20
exp
3
x
0.001
exp
-6
1/x
Maybe you should just get a graphing calculator where you can enter this kind of stuff as is :)
ubuntupokemoninc
Wed Dec 22 2010, 02:53AM
You left out the 10 before the exponent, what would be the value of Rt If i need 110khz and the value of Ct equals .001uf?
On a Tl494 chip
Pinky's Brain
Wed Dec 22 2010, 04:06AM
ubuntupokemoninc wrote ...
No, I didn't ... exp includes that. If you wanted to explicitly do 20x10^3 you'd do :
20
10
x^y
3
If your first formula is correct you need 10 kOhm.
ubuntupokemoninc
Wed Dec 22 2010, 02:03PM
10k for 110khz?
thanks man! I'm in 8th grade and i'm not very good at math mistrust
