  • Guests: 38
seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
MO protection diode
Ash Small
Tue Dec 21 2010, 05:39AM Print
Can anyone tell me anything about microwave oven protection diodes?
Can they be used for anything else?
A lot of microwave ovens seem to have these, they are connected across the capacitor. Apparently they are designed to blow if the rectifier diode (voltage doubler diode) blows, thereby blowing the fuse and preventing the transformer from burning out (from what I've 'gleaned' from googling).
They have a shematic on them showing two diodes cathode to cathode, one larger than the other. The one I have is part number: 2X062H.
Do they have any use in other circuits, or should I just bin it?
Tue Dec 21 2010, 10:42AM
Ash Small wrote ...
Back to back series diodes protect a circuit from bidirectional transient threats, by clipping off peaks above and below what are called their clamping voltages, which are determined at their point of manufacture. They can be either symmetrical, clipping negative and positive transients at equal voltages, or asymmetrical, where the positive and negative going transients are clipped at different voltage levels.
Ash Small wrote ...
Why have two things that blow? smile
wrote ...
You might need it to repair a microwave oven! smile
