  • Guests: 52
Anyone know what B+, VCP and ABL markings mean?
Steve Hobley
Tue Dec 21 2010, 12:50AM Print
Steve Hobley Registered Member #1731 Joined: Thu Oct 02 2008, 02:22PM
I have a flyback taken from an old Gateway monitor - it's marked
6174Z-1038A
1AJ 09
On the PCB the terminals are marked with output voltages and ABL, VCP and B+.
Anyone know what they mean?
Steve
Dr. ISOTOP
Tue Dec 21 2010, 01:18AM
Here's the answer, according to Yahoo Answers:
1.180V------------------------supply to video circuits
2.Heater----------------------tube's heater supply
3.nothing
4.25V------------------------- etc
5.B+---------------------------main supply voltage from power supply
6.ABL--------------------------beam limit
7.COL-------------------------collector of HOT
8.AFC------------------------ etc
9.GND
10.nothing
Steve Hobley
Tue Dec 21 2010, 09:54AM
Hey thanks for the reply - I did see that, but does anyone know what beam limit actually does, and VCP is not mentioned
Antonio
Tue Dec 21 2010, 01:32PM
Find the schematic of the board. Usually the pins below are the primary coil, several other coils to generate other voltages, one of them used as feedback to regulate the output, and ground pins for the main coil, potentiometers, filter capacitors and bleeder resistors.
Steve Hobley
Tue Dec 21 2010, 01:44PM
I've been looking for a schematic, but the usual places aren't turning anything up - I can see it listed as a part on the manufacturer's site, but no schematic.
Antonio
Tue Dec 21 2010, 08:30PM
Try this site for the schematic:
Xray
Tue Dec 21 2010, 09:54PM
Xray Registered Member #3429 Joined: Sun Nov 21 2010, 02:04AM
Steve Hobley wrote ...
6174Z-1038A
1AJ 09
Steve
The marking labeled "B+" originated from the old days when vacuum tube circuits were battery powered. The filament supply was called the "A Battery", the plate (anode) supply was called the "B Battery", and the grid bias supply was called the "C Battery". When TV's became powered by the AC line, engineers continued using the B+ designation for the high positive voltage (generally a few hundred volts) that fed the plate circuits. Since the filaments were powered by a low voltage winding on the power transformer, the "A" designation was no longer used. Also, the "C" designation was no longer used for the grid bias supply.
ABL stands for Automatic Beam (or Brightness) Limiter. It's a circuit that limits the brightness of the CRT in order to prevent the phosphor from getting burnt. You can find patents and other detailed information about it's function by searching on Google.
Th3_uN1Qu3
Sat Dec 25 2010, 11:27AM
Th3_uN1Qu3 Registered Member #2614 Joined: Sat Jan 09 2010, 08:57AM
Now coming to what you're actually interested in - the B+ winding is of use to you only if you plan on using a mains-powered driver as it needs to get at least 130 volts to generate any useful HV. If you intend to power your driver from 12 volts, you need to do your own primary winding. Most flybacks have some of the core exposed for deriving the heater winding, so that won't be a problem. Start from 6 turns and go down - the less turns the higher the output voltage, but go too far and you'll ask for too much current from the switching device and blow it.
I used to run a flyback from a 17" monitor with a IRF640. I used 4 primary turns and never fried the MOSFET, but the heatsink it was installed on used to cool ALL the power transistors in that monitor so it was quite big.
UbuntuNinja
Tue Dec 28 2010, 04:07AM
UbuntuNinja Registered Member #2677 Joined: Mon Feb 08 2010, 03:06AM
While we are on the subject of flyback transformers, does anyone know any good tricks for figuring out which of the many sequences of numbers marked on a flyback transformer is the specific part number (i.e. the number that could be used to find a datasheet)?
Ash Small
Tue Dec 28 2010, 04:23AM
Can you post some photos of it (including numbers)
Do you know the make of the flyback?
(the make of the TV/monitor it came from may also be useful)
