  • Guests: 55
jacobs ladder in science fair?
ubuntupokemoninc
Wed Dec 08 2010, 09:20PM Print
ubuntupokemoninc Banned on 1/22/2011 for repeated rule violations after multiple warnings.
Registered Member #3299 Joined: Sat Oct 09 2010, 08:11PM
my little brother wants to make a jacobs ladder for a science fair project but what can he prove with a jacobs ladder?
Wed Dec 08 2010, 09:22PM
That heat goes up?
It would need to be in a completely sealed container to be used at a science fair I guess...
ubuntupokemoninc
Wed Dec 08 2010, 09:28PM
the whole point is to scare his mindless teachers cheesey
he was gonna use one of my obits, not enough to kill any one.
Dr. ISOTOP
Wed Dec 08 2010, 10:13PM
Air can conduct electricity given enough voltage?
How old is this brother of yours...?
ubuntupokemoninc
Wed Dec 08 2010, 10:19PM
9 YEARS OLD! Any suggons for building a jacob ladder with the scientific method?
Killa-X
Wed Dec 08 2010, 11:14PM
If it's for a science fair...You might want to make sure people have something to keep their distance from it. I would either put some type of cage around the ladder, or at least fence the area a little bit. Last thing you'd want is for some kid to get interested and try to touch it...
Using a simple neon transformer, given its not too much info to explain, he could tell how the transformer converts 120V to 12,000V. The ladder obviously would show how electricity can arc across the air, How plasma forms around electricity maybe? But as said already, it demostraights how heat rises. The arc goes up, since the heat goes up. Arcs are so sensitive to any air movement, that the heat causes the arcs to rise...
I think it will be a good science fair project, given you take the right precautions and can explain it. Keep safety in mind, as you cant expect people to keep their distance, and not run over and try to touch it.
If you had the tech, a nice laser-trip field would be cool =D Shut it off when anyone steps in =)
Antonio
Wed Dec 08 2010, 11:48PM
This is too dangerous for this age. And making the enclosure would be much more complicated than making the device. All the fun is in not having any enclosure and knowing that the device is dangerous and how to operate it safely.
2Spoons
Thu Dec 09 2010, 12:45AM
Plus the obvious hazard of NO2 generation.
GluD
Thu Dec 09 2010, 01:09AM
GluD Registered Member #1221 Joined: Wed Jan 09 2008, 06:17PM
I have never experienced any problems with NO2 from any of my arcs, so I wouldnt call it a hazzard unless its a very big jacobs ladder in a very small room.
ubuntupokemoninc
Thu Dec 09 2010, 01:29AM
i will be supervising him in this project, and making sure its safe.
