  • Guests: 57
Which one ?
ZakWolf
Sun Dec 19 2010, 11:13PM Print
I have built both of these flyback drivers, but which one is best and whats the difference between the two? How can i get better power output and not destroy the 555 timer. (i already have a ZVS flyback driver). Why does audio modulating draw so much current ?
Also which one is better to audio modulate? if these are no good could you post some good audio modulation circuits. Thanks :)
1292800382 3114 FT0 555 Flyback Driver
Drv2
Ken M.
Mon Dec 20 2010, 12:22AM
THe top one is better for the 555 since it lets you have more primary voltage and over load the regulator or the 555, as far as audio..no idea.
cjk2
Mon Dec 20 2010, 01:35AM
No one seems to design these very well. Build the first one but put a snubber or quasi-resonant circuit on the primary side of the flyback. If you don't do this, you will waste lots of energy causing the FET to avalanche every cycle. If you do insist on building this with no snubber, use a high voltage FET (like 1200v) so that the output voltage is not clamped by the FET avalanching.
The 555 drivers are somewhat bad anyway because there is no way to adjust duty cycle and frequency independently. I would recommend a TL494 or other PWM based driver over this one.
ZakWolf
Mon Dec 20 2010, 01:44AM
cjk2 wrote ...
Do you have a simple circuit of the tl494.
When i ordered some i accidently ordered them in surface mount but that shouldn't change the specs right
where would i find a quasi resonator circuit ?
cjk2
Mon Dec 20 2010, 02:31AM
How about this one http://4hv.org/e107_plugins/forum/forum_viewtopic.php?70382
For quasi resonant drive you should choose a cap to stick across the FET that will resonant with the inductance of the flyback at maybe 20 khz or so. Use a resonant frequency calculator if you know the inductance of the flyback. Then use a scope to watch the D-S voltage of the FET and twiddle the frequency of the 494 until you see a critically dampened waveform.
If this is too hard, I suggest buying a 1200v FET with the lowest Rds(on) you can afford.
Mon Dec 20 2010, 02:33AM
cjk2 wrote ...
That is why i use the 74hc14 hex inverter.
Mon Dec 20 2010, 06:33AM
yeah, i think the commercial plasma globes use a 4069 as these can be used in linear mode to make a tesla coil-like resonant setup.
IIRC this is so that when someone touches the globe the power goes up so it doesen't waste energy running it at 100% all the time.
-A
ZakWolf
Mon Dec 20 2010, 07:12AM
i made the top circuit and when i connect an 18v 2.5 amp bat. the irfp250 gets supper hot what do i do to prevent this or is there something i can add to make it more efficient.
cjk2
Mon Dec 20 2010, 08:00AM
"i made the top circuit and when i connect an 18v 2.5 amp bat. the irfp250 gets supper hot what do i do to prevent this or is there something i can add to make it more efficient."
Like I said, you need a proper high voltage FET to build a proper flyback driver. The fet is hot because it is analanching every cycle. Use a 1200v part and build a snubber to limit the peak D-S voltage to 1200v. If you don't do this, then the FET will avalanche and hence will be very hot.
To summarize: Use a real PWM driver with a TL494. Use a 1200v FET. Try a snubber if the FET still gets too hot.
Ruben
Mon Dec 20 2010, 12:02PM
Ruben Registered Member #3263 Joined: Sat Oct 02 2010, 04:43AM
what does that achieve?
LittleVenture, you could check out this thread:
