  • Guests: 36
seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
gu-5b questons
ubuntupokemoninc
Sun Dec 19 2010, 05:27AM Print
ubuntupokemoninc Banned on 1/22/2011 for repeated rule violations after multiple warnings.
Registered Member #3299 Joined: Sat Oct 09 2010, 08:11PM
I think I've finally made up my mind, I'm gonna go with the gu-5b,
first (It doesn't say this on the data sheet) do the filament pins face down during operation?
will the filament take 60hz?
can it be water cooled just like in liquid plasma?
Sun Dec 19 2010, 08:45AM
ubuntupokemoninc wrote ...
Normally a glass envelope tube would be mounted with pins down or to the side. With a tube like the GU-5B that have a jacket it needs forced air cooling, it will be enough for shorter runs, water cooling could get expensive to make and its more of a mess than air.
As long as its sufficiently cooled -i do not think the direction matters
You could supply the filament with 12.6V DC, if not from a heavily filtered large rectified transformer, then some car batteries, but watch the voltage closely, if you supply a filament with less its rated voltage you risc that the electron emission will go from the polluted materiel and ruin the tube.
Dr. H.
Sun Dec 19 2010, 08:57AM
Those kind of power tubes are supposed to work ONLY vertically (the internals sag from heat and time). And most of the GU series are suppoed to work with pins UP.
And one more thing - I don't advise you on building your first coil on a GU-5 ... build something small and then go on to the big stuff.
Cheers
ubuntupokemoninc
Sun Dec 19 2010, 02:10PM
It's not my first its my second wink
