  • Guests: 40
seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
60 TIP-122's
Adam Munich
Sat Dec 18 2010, 04:22PM Print
I've got 60 TIP-122's and no clue what to do with them. Any ideas?
ubuntupokemoninc
Sat Dec 18 2010, 05:18PM
ubuntupokemoninc Banned on 1/22/2011 for repeated rule violations after multiple warnings.
Registered Member #3299 Joined: Sat Oct 09 2010, 08:11PM
make banks of them in series parrelel, and a zvs on rectified mains
Adam Munich
Sat Dec 18 2010, 05:22PM
Putting BJT's in // is a bad idea...
radiotech
Sat Dec 18 2010, 07:51PM
Keep them until you have 60- TIP-121s then youi will have 60
complimentary pairs.
Avalanche
Sun Dec 19 2010, 12:35AM
you can run BJTs in parallel as long as you put sharing resistors in the emitters smile I recently serviced some antique equipment at work that used large banks of 2N3055 type transistors in parallel (I forgot the exact part number) and the emitter sharing resistors were what looked like springs, just coils of stiff wire.
I have been in a similar situation before with parts, and I just stick them into a drawer and forget about them for 10 years cheesey 10 years later I have so much stuff I can't move cheesey
Sun Dec 19 2010, 09:26AM
ebay smile
someone has to want them, they are handy for repairing pinball machines as well as small fluorescent tube drivers.
-A
Sun Dec 19 2010, 01:45PM
put 30 in series and make a filtered MOT supplied single switch SSTC
Wolfram
Sun Dec 19 2010, 03:28PM
Mads Barnkob wrote ...
I assume this was a joke, but just in case, this will not work. A rectified MOT would provide around 3kV, 30 in series would handle about 3kV, but for a single switch SSTC, you would want a switch that could handle many times the DC supply voltage. Secondly, you would need to provide 60 insulated gate drive signals. Lastly, these are low speed switching transistors, and they would not work very well at SSTC frequencies.
Sun Dec 19 2010, 04:22PM
Anders M. wrote ...
It was a joke to throw oneself into making a driver for that :)
radiotech
Mon Dec 20 2010, 05:18AM
You could wire them up ito some binary logic.
2 would make a bistable multivibrator.
It wasn't uncommon to have a 4 x 12 inch circuit
card with 8 transistors on it plugged into a frame on
rack in a room filled with them.
