  • Guests: 40
Have NST Waveforms...Need Help.
Fri Dec 17 2010, 04:24AM Print
Ok, i used a voltage divider to capture these pics...
1292559862 2431 FT0 Cap1
above: single yellow trace, from the 6kv-ground of NST. (10x probe)
1292559862 2431 FT0 Cap2
above: yellow trace is same as previous pic. blue trace is 1x probe.
UPDATE: new waveforms.
1292562517 2431 FT1630 Pic3
blue trace is wall voltage/current divided down. yellow trace is as above.
1292562517 2431 FT1630 Pic4
Tick marks and lines for deltas.
EDIT:At least 1/0.016760s = 60Hz
my question is why is it not more sinusodal? i expected it to be a little noisy, but its so irregular.
let me do some math: if Vrms = Vp/root(2) then...
19.3/2 = Vp = 9.65V so...
9.65vp/root(2) = 6.82V as expected
so 6.82V X 1000 = 6.82kV!!!
I dont know about this ...but perhaps its the magnetic core shunts, which are used to limit short-circuit current. They may allow a sort of linear rise until clipping, then it flips back and forth to approximate a sinusoid?
Pinky's Brain
Fri Dec 17 2010, 05:18AM
As for the voltage, resonant rise?
Fri Dec 17 2010, 05:38AM
Pinky's Brain wrote ...
No i goofed on the math, thats fixed now. But why so non sinsoidal? do others with the p6015 (or other probe) get the same for thire NST's too?
Xray
Fri Dec 17 2010, 05:56AM
Xray Registered Member #3429 Joined: Sun Nov 21 2010, 02:04AM
Patrick wrote ...
That would be MY guess. I think you got it right!
Are there any transformer guru's who can confirm this?
Fri Dec 17 2010, 06:04AM
I hope its that simple.
Fri Dec 17 2010, 07:21AM
oops my computer bothced this post, now its a double post-sorry. sad
heres this newest screen cap.
1292570500 2431 FT103594 Pic5
1292570500 2431 FT103594 Pic6
this looks better, properly scaled.
Fri Dec 17 2010, 09:36AM
Try looking at the mains voltage directly, it's never a pure sine wave.
Also, even if it was, the magnetic non-linearities in the NST will distort it, and the leakage inductance and self-capacitance of the secondary will ring from those distortion harmonics. Purity of output waveform was probably quite far down the NST designer's to-do list.
Fri Dec 17 2010, 10:02AM
So do the wave forms I've captured look like a "normal" NST?
Steve McConner wrote ...
i did not expect it to be perfect, i just want to see if my resistive divider is out putting credible data.
Sat Dec 25 2010, 05:19PM
I think these oscillograms are accurate, for the yellow trace (5 kV per div) at 19.3 kVp-p X 0.707 = 13.6 kVrms which is really close ( better then 2% ) of what the DMM + R divider said.
