  • Guests: 35
  • Most ever online: 596
    Guests: 596, Members: 0 on 25 Oct : 21:25
WaveRider (62)
Njubster (34)
10/30 Aragorn (41)
10/31 Tor (40)
10/31 RussT (67)
405nm laser and uranium glass marbles
radhoo
Tue Dec 14 2010, 11:27PM Print
Since we're getting closer to the winter holidays, and we're used to see little lights all around, here's another picture with uranium glass green fluorescence, when illuminated by UV:
1292369261 1938 FT0 Dsc 30832
The "normal" glass color: Link2
dmg
Fri Dec 17 2010, 08:20PM
Thats pretty cool, where did you get the 402nM laser from? all pens I see are 405
radhoo
Tue Dec 21 2010, 08:10AM
You are right, I've corrected the typo.
dmg
Tue Dec 21 2010, 03:11PM
aww... sad
I started to get my hopes up...
Wed Dec 22 2010, 07:37AM
hmm, don't 405nm lasers change wavelength when cooled down?
402nm might be possible at like -30 Celsius.
(cough peltier cascade /cough)
-A
dmg
Wed Dec 22 2010, 01:54PM
Eh, Ill try that out for fun, see if there is any noticable differance.
peltier shmeltier, Ill just put it outside for an hour... its already -35C anyway..
Meatball
Wed Dec 22 2010, 06:11PM
Meatball Registered Member #2401 Joined: Mon Sept 28 2009, 04:25PM
405nm diodes actually vary quite a bit. I had a 12X that lased at 408nm, and a PHR that lased at 401nm. The 12X was noticeably brighter, even at lower powers. You could drop that diode in a glass of distilled water, that's a nice way to heatsink it. Just make sure you clean the diode window afterwards.
dmg
Wed Dec 22 2010, 08:05PM
Ive got a few PHRs around, I suppose I can try that too later.
are you on LPF Meatball?
Meatball
Wed Dec 22 2010, 10:04PM
Yep. You?
Here's one thread I found, but I can't seem to find the thread where a LOC was dunked.
dmg
Wed Dec 22 2010, 10:05PM
yep, im GBD there..
wouldn't doing this with a C-mount as shown wreck the die if water got on it?
(water will cause COD?)
well, I dont have any C-mounts anyway, but was just wondering.
