  • Guests: 35
seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
555 counter curcuit
ubuntupokemoninc
Sun Dec 12 2010, 04:17AM Print
ubuntupokemoninc Banned on 1/22/2011 for repeated rule violations after multiple warnings.
Registered Member #3299 Joined: Sat Oct 09 2010, 08:11PM
I am in science Olympiad for school, one of my events is called battery buggy,
basicly i need to create a car that runs on 4.5volts, and the give me a distance, i set the car, and the person who gets the closest to the distance they gave us wins, as soon as i heard, 555 counter poped in my head,
found this, not sure if its what i need
basically if I put a pot on pin 5 to set the lenth and a push botton switch to trigger the curcuit, it will cycle threw the time, and then be off unless triggered again, is the curcuit i showed you what i described, if so will it stay on for say 20 seconds or more, what values should i use for this?
Adam Munich
Sun Dec 12 2010, 04:36AM
Seach "monostable 555 timer"
Sun Dec 12 2010, 07:51AM
A 555 timer is good and you should get close to your target.
like robot wars, the best machine doesn't mean the best result.
practice, practice, practice.
For better accuracy you would need some kind of 'dead-recconing'
- counting wheel rotations is fairly obvious
- if the rules allow it, ...
a piece of string/cotton of the target length attached to the start line could be used to stop the vehicle.
This is a better engineering approach
(guaranteed result, cheap, simple, reliable)
So, take a reel of cotton with you as if it is allowed you don't need anything else! tie one end of the line to the on/off switch and thread the line through to the rear of the vehicle. Attach the other end to the START line.
At the correct distance the thread will turn off the motor AND hold the length..... can't lose.
Sun Dec 12 2010, 10:52AM
id use a 4017B chip or 2 and use a switch attached to a wheel as a clock to count how many turns it goes around
on monday or tuesday when im back at school il make a mock up on circuit wizard if your interested :)
ubuntupokemoninc
Sun Dec 12 2010, 04:07PM
I already drew up the circuit and ran a test on on circuit maker pro,
the thing is is the cap needs to be huge, and the pot needs to also have a huge value!
but it work on the scope on my program thanks everyone
Adam Munich
Sun Dec 12 2010, 04:24PM
How huge?
Sun Dec 12 2010, 04:34PM
For long time delays, it's often better to use a 4060 Link2 instead. That's what is hooked up to the browning control on a toaster.
Ash Small
Sun Dec 12 2010, 05:42PM
If you want to be able to program the distance exactly and you have access to a PC notebook, and you can get an old HP dot matrix printer, you could do what I plan to do for my current project.
Use one drivewheel (a three wheeler would make sense here) and write a simple DOS program to run one of the stepper motors using the existing HP circuitry.
All the software stuff is easy to get and you can program it to go any distance you like. (just work out how many 'line feed' commands or whatever you need to send to the circuitry to drive it an inch, or whatever.
Any programmable stepper motor design would work, I've just suggested the simplest and cheapest method I can think of, and one I'm planning to use myself.
EDIT: on second thoughts you might need a parallel port on the notebook (printer port). someone may be able to suggest a way round this, though.
Ruben
Fri Dec 17 2010, 03:44AM
Ruben Registered Member #3263 Joined: Sat Oct 02 2010, 04:43AM
Any AVR, PIC etc can be rigged up quite simply to drive a stepper motor. (google < micro controller of your choice> stepper motor)
This should give you quite accurate results provided you're able to set the distance in software prior to your run, and you can ensure that the wheels dont slip.
Using the 555 or another delay based method will mean you get varying distances as your batteries drain. this will be a royal pita as you try to calibrate things
Does your competition have any other pertinent rules?
ubuntupokemoninc
Fri Dec 17 2010, 09:44PM
All batteries are provided so we will just keep switching them out, because we don't have to pay for them cheesey
