  • Guests: 92
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
solid state phase converter
ubuntupokemoninc
Thu Dec 09 2010, 02:34AM Print
ubuntupokemoninc Banned on 1/22/2011 for repeated rule violations after multiple warnings.
Registered Member #3299 Joined: Sat Oct 09 2010, 08:11PM
found this on google images, is it "reasonable" to be able to run a 3 phase 12 mot stack off this? with obviously a bicker brick of IGBT?
if not maybe a 6 stack, plus this picture is such a bad resolution on my monitor i can't read the components, maybe some one with a better monitor, could make this schematic readable on a crt.
Thu Dec 09 2010, 03:13AM
What is the point of using three phase? People usually use 3 phase because you can get more power. With three phase with MOTs you have to rectify each phase, anyway. If you are using single phase to power a 3 phase converter, you won't get any more power than with single phase.
Thu Dec 09 2010, 10:36AM
That schematic is incomplete anyway. The hard bit is missing, the DSP that generates the waveforms.
radiotech
Thu Dec 09 2010, 07:15PM
If you look back in the history of electrical
power transmission, you will see that Edison
invented the 3-wire balanced circuit which
reduced the pounds of copper per watt
needed.
The polyphase power system can transmit
more power per pound of copper than the
single phase system can.
ubuntupokemoninc
Thu Dec 09 2010, 09:57PM
can some one tell me were i can get a good schematic then?
AleSeg
Fri Dec 10 2010, 10:10PM
AleSeg Registered Member #2727 Joined: Tue Mar 09 2010, 02:39PM
Error:
Radiotech said:
"If you look back in the history of electrical
needed."
Tesla was who invented the 3-wire systems. And was in a fight with Edison, who sustained that DC were better than AC.
Cheers
Sat Dec 11 2010, 03:22PM
No, this is the 3-wire DC system, with one neutral and two wires carrying + and - 110V DC.
